I have a HDfury2 connected to a Panasonic Blu-Ray player. However there does seem to be horizontal banding in the picture, especially in scenes with mixed light and dark content. I've tried just about every control I could think of: adjusting brightness and contrast on projector, adjusting brightness and contrast on Blu-Ray player, adjusting black level (Lighter or Darker) on Blu-Ray player, turning off deep color, turning off Viera Link, turning off audio through HDMI, even adjusting the phase and position of the picture on the projector. Nothing seems to be improving the situation. I have tried bypassing the KVM that I am temporarily using as a RGBHV switch for the projector, and I have tried removing the HDfury2 power supply.
The only thing that seems to work is if I change the output resolution from 1080p. It looks perfectly fine on 1080i, for example. I am using a HDMI 1.4 cable. Is there anything that can be done about this, or is it likely a problem with the Fury? Even if I could compensate for it through some settings on a video processor (Lumagen Vision DVI, DVDO iScan VP-30, etc.) that would be fine. Would that be possible?
