AVS › AVS Forum › Audio › Speakers › Klipsch RS-52 II wall mounts
post #1 of 3
I need some wall mounts for my speakers and it looks like theres a couple holes pre-drilled in them for adding a mount. My googling hasn't turned up anything and was wondering what others were doing?
I just need tilt as I need to mount them a bit higher than normal, around 7 feet in the air.
post #2 of 3
i used large wood screws directly into the studs. if you need them to tilt, use longer screws and some shims at the top.
post #3 of 3
I swear I saw a mount that fit them perfectly before, but can't find it again. I should have bookmarked it.
  Back to Forum: Speakers
