I'm finalizing some of my screen wall dimensions prior to drywalling and wanted to get some opinions on mounting the screen.
Here is a side view of my screen wall as it's currently designed:
I had planned on setting the screen (AT SeymourAV) into the wall for two reasons:
1) to minimize reflected light from the screen to the surrounding theater (I'd be covering the surrounding surfaces with velvet)
2) to maximize the viewing distance (total HT depth is about 19'6")
As I'm getting closer to actually building this, I'm second guessing some of the reasoning.
Should I just make a flat screen wall maybe 28" or so from the back wall? Is there truly a benefit to setting the screen into the wall?
Thanks for any help.
