AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Which material for screen wall?
post #1 of 19
Screen wall will be covered with 2" thick Roxul AFB, and need material to cover it. I was hoping it wouldn't be too expensive, but covering a 13'x9' wall seems to be like 100 bucks+ with GOM 701. So which would be best (for the price):
GOM 701
vs
Stretch Velvet from Joanna's
http://www.joann.com/joann/catalog/p...DID=xprd768914
VS
Micro velvet black from Hancock:
http://www.hancockfabrics.com/Micro-...VVviewprod.htm
VS
microsuede from ats
http://www.atsacoustics.com/item--Mi...ide--1027.html
Joanna's and ats is WAY cheaper... so I'd go with that unless it won't work well...
post #2 of 19
I doubt anyone has done a scientific analysis comparing the three. I'm happy with the Hancock and if you wait it occasionally goes on sale for 50% off on-line. You can also take a competitors coupon into their store.
post #3 of 19
Look at it this way - how much have you already put in the room to make it look and perform the way you want it to? Is $100 really that much ? If you spend $50 instead on an unknown fabric will it be worth it to you ?
You asked this same question in another thread.
JMHO
post #4 of 19
I haven't gotten around to pricing GOM yet so my initial reaction was "Only $100?!? Awesome!"
I know that BIGmouthinDC has glowed about using the Hancock micro velvet in other threads. His theatre's crazy snazzy so I put a lot of value in his answer!
post #5 of 19
When I wrote the post originally I calculated it out to be over 300 bucks! Then I remembered the price is per yard, not per foot. 100 isn't bad, and I do like the way Biggy's wall looks, so might just bite the bullet and order that for my screen wall and other bass traps.
Thanks guys
post #6 of 19
Agree, his theatre is really snazzy. It is just that is twice the price of Joannas fabric, so was hoping someone's used that and hoped it worked well. I just realized I need to get about 20 yards total, so would save me quite a bit.
post #7 of 19
I think McCall used Joannes in her theater.
post #8 of 19
It was definitely stretch velvet, but don't recall the source.
post #9 of 19
If it saves you some money you should go look at the Joanne's. If you like what you see, use it.
post #10 of 19
I went to Hancock tonight to look at the micro velvet. I tried breathing through it and could feel my breath a little bit, if I had to guess I'd say a quarter the power I breath into it.
I'm going to check out Joann tomorrow and compare. Joann is 33% the price and is a lot wider too. I did like the look of the micro velvet though
post #11 of 19
Don't forget about flammabiltiy ratings - if that's important to you. There is a reason that some of these fabrics are more expensive than others.
When I did my theater, I relied heavily on the acoustic properties of the material as well as the flammability ratings. I paid particular attention to the acoustic properties of the material that was covering any of my speakers.
post #12 of 19
Just FYI, if you're going to JoAnn's, check out the 'Premier Velvet' in addition to their 'Stretch Velvet.' It's the same type as the 'Micro Velvet' over at Hancock's, and with a 50% off coupon is within the same price range.
I did the same thing and compared the stretch to the premier. The stretch velvet definitely has better AT qualities, but since my speakers are behind the screen and not the fabric, I thought the Premier Velvet was a much nicer material and worth the little extra cost.
post #13 of 19
My screen wall was syfabrics.com triple black velvet. Looks great, cant speak to its AT properties though...
post #14 of 19
Just a data point. The much used GOM FR701 fabric provides a similar breath test result. I remember posting years ago that it felt like a 3-4 out of 10.
post #15 of 19
Does the micro black velvet From Hancock have any requirements as far as orientation? People said the one from Joann's needs to be installed a certain orientation.
post #16 of 19
Not that I noticed. My top and bottom are at 90 degrees to the left/right. I can't see a difference.
post #17 of 19
The Hancock website states that the micro velvet is now Discontinued... frown.gif
Micro Black Velvet
Item# 128157
•Contents:100% Polyester
•Width:44"
•Care Method:Dry clean only.
•Bolt Size Average: 15 Yds.
Availability:
Discontinued
post #18 of 19
post #19 of 19
Originally Posted by cdika17 View Post
People are starting to use this now:
http://www.syfabrics.com/View.aspx/Plush-Triple-Velvet/Black-Plush-Triple-Velvet/681/264
Thanks for the heads up!
