Would someone be able to point me to the proper RS-232 cable to purchase, to go between a Global Cache IP2SL and a JVC DLA-RS2 projector? I've been all over Monoprice and am not entirely sure which cable fits the bill. A link sure would be appreciated.
Would this cable, along with any necessary gender switchers since I need a female-to-female cable, do the trick? Link to Null Modem Cable.
For reference, here is what the RS2 manual says about its RS232 connection:
Control of this unit via a computer is possible by connecting the computer to this unit with a RS-232C cross cable (D-Sub 9-pin)
The IP2SL specs are equally unclear to me, in terms of understanding which cable to buy:
Male DB9 Connector
1200 baud to 115 Kbaud Data Rates Supported
Odd, Even, and None Parity Settings
Bi-directional hardware RTS/CTS Flow Control
I'd prefer to buy a pre-made cable, but if that's not possible, would someone be able to tell me the exact adapters from Monoprice that are necessary to build one?
With Roomie, what kind of feedback is possible from the RS-2?
For purposes of full disclosure, I also posed this question in the iRule thread.
Scott
Would this cable, along with any necessary gender switchers since I need a female-to-female cable, do the trick? Link to Null Modem Cable.For reference, here is what the RS2 manual says about its RS232 connection:
Male DB9 Connector
Scott
