I have read tons of links and still don't quite understand how to calibrate a subwoofer. If I have an SPL meter (radio shack), what exactly am I doing and in what order? I understand subs are supposed to be calibrated @ 75db, but I don't even know how to get there. Run Onkyo test tone and adjust onboard level until meter reads 75db? Then, in some places it mentions setting mains first. I'm totally confused.
I would just run Audyssey but my sub manufacturer advises AGAINST using it (Elemental Designs). I'm also running dual subs, and what I've seen mentions calibrating them together, not one at a time. I just need someone to spell it out in simple steps or terms. I don NOT have any burned test tones at this time, so I'm just using the test tone that the Onkyo has onboard. Thanks guys...I'm reading everything I can but most links assume you know the most basic steps...and I don't
FYI...right now my subs have the their volume set @ 12:00 and the Onkyo level is set at -9.0db. Distance is set same as mains...which they are. hose two settings were what Audyssey recommended, but I have turned Audyssey off, but kept those 2 settings. My mains are crossed at 60hz, center and surrounds at 80hz and my LPF for LFE is set to 100hz crossover. As of right now I'm mildly underwhelmed by the subs, but if I creep up the gain on the receiver the subs get too hot for some movie passages. I just want to calibrate it in such a way where I can comfortably crank my system for most movies without having to turn down the subs.
Running dual A5-350's...setup in my room in a "stereo" config...1 between center and each main in front of seating position.
