OK so for those of you who have done the fan mod, which direction does the cooling fan blow?
I bought an EP4000 second hand and the fan mod was already done. Right now the fan blows into the chassis. If this is the direction its supposed to blow why is there a filter on the front? Doesnt make sense to filter the air on way out does it?
And then furthermore the manual says back to front cooling, so which way should it be?
