AVS › AVS Forum › Video Components › Home Theater Computers › Setting Up The HDHR Prime + Tuning Adapter (Cablevision)
post #1 of 3
Quick question, I just picked up the HDHR Prime and since I use Cablevision I am required to use a Tuning Adapter as well. I already have the Prime set up with the cablecard and installed on my PC. The next step is to get it added in WMC. I see that when I go through the WMC setup at some point I will need to call Cablevision to get an activation code. Also, on the Tuning Adapter instructions it tells me I need to call Cablevision to activate the TA. Any ideas if I should be calling to activate the TA first before I start with the WMC activation process, or it probably doesn't matter?
On a side note, trying to get in touch with Customer Service to activate a cable card during a hurricane is probably not the best idea lol. I will have to try again tonight when I get home from work.
post #2 of 3
activate the card ahead of time, trust me !
post #3 of 3
Thanks, hope to do tomorrow when i get home.
