G'day Bouncy,
I having a bit of trouble understanding your question, but for example, if your Humax is connected to SAT/CATV and the Sony PS3 is connected to GAME, you just press the relevant input button to select the input you want. And what you have selected lights up on the front panel display off the DH820.
And as for HDMI pass through, the "default" HDMI input is the last one you had selected. If you are looking at TV and have SAT/CATV selected, and turn off the DH820, then later turn the DH820 back on, it comes up on SAT/CATV.
Actually you can have all four HDMI inputs connected to different equipment that is switched on, and only the input for the button you have pressed (and shows on the front display panel) passes through to your TV/monitor. You don't have to turn the others off.
Does that make sense?
