I've got this one:
http://www.ebay.com/itm/140454429933
Works very nice (also 3D compatible), with two tiny caveats and one big plus. The two caveats are: it can't be switched off using the remote and it's a bit sensitive to random IR fire from other Taiwan stuff (e.g. from my Dune player's remote). The big plus is that is enables HDCP-encrypted output from devices even if the display does not support HDCP.
The link above is from a german dealer, but you should be able to find the same one stateside.
