AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Passive sub
Passive sub
post #1 of 4
I was given a bsr passive sub that needs some work.
Can I use my equalizer with this sub and two satelites.
I don't want to put too much work into the sub if I can't
use my (EQ).
Thanks for any help
Toehead
post #2 of 4
If you put the eq in line ahead of your subs amp, then sure you can use it.
post #3 of 4
Thanks Jay
I ordered a new foam ring for the sub and will do the repair.
I'm hoping the sub is worth fixing. It's a BSR dr-sw15×2 any thoughts.
Thanks Toehead
post #4 of 4
Don't know anything about it, but Googled a bit, looks like they can be had used for anywhere between $15 () and $100 - so don't put too much money into fixing it, but if you can do so cheaply, why not.
