AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › New House, because I love this stuff.
New House, because I love this stuff. - Page 4
post #91 of 507
Originally Posted by BrittonYoder View Post
Last night I began working on wire management.
went a little nuts with the service loops huh? Although i suppose in some cases you may go up and the down a 8ft rack for neat routing so thats 16ft right there....
post #92 of 507
Yeah it's a little much but I used to work with a guy who cut everything too short and it drove me nuts. I will tie up the slack below the racks. I cut it 1.5 times the height of the rack.
post #93 of 507
OK, so here is something you can't often say... "Dude, I love your rack!"
post #94 of 507
lol, I appreciate that
post #95 of 507
Ok, going on 48 hours with no updates - did your rack fall on you?
On a side note, I paid over 2x what you did for my 26 year old house here outside DC, and have nothing like you're building there - color me green with envy!
post #96 of 507
Work fell on me! I am not really a morning person and had to leave for work at 6am all week and worked 60 hours. I finally have recouped and will be posting new pictures soon. Move to Texas, for double you can get an estate. Or you could just spend what we did and buy some more toys. :-)
post #97 of 507
We got some of our new furniture this weekend, which means the stuff that was supposed to go in the media room with finally be going back into the media room.
post #98 of 507
I re-wired my power strip so that every other outlet was on a different circuit. This took forever.
post #99 of 507
This is how it turned out. I have some of the small stuff (modem, router, ect.) on switched UPS outlets so that I can power cycle them when I am out of the house is something goes down. The other stuff, is just on UPS.
post #100 of 507
I finally got one of the baluns working. I originally terminated all of the cat-6 with EZ-RJ-45 ends and they don't seat properly in the baluns. Only the cheap monoprice ends seem to work well. Horrible!!! My fingers are tired. Time to redo a lot of ends tonight.
post #101 of 507
I've got to order a new screen this week. I have been going back and forth on what to get. I know that I want to order a Stewart, but I am unsure of the size, screen material and aspect ratio. We will be sitting 12' from the screen.
Materials:
G3 Firehawk - This is the screen I have owned for years.
Studiotek 130 - Thinking about this since it is a dedicated room this time around. Would allow larger screen with lower output on the projector.
Studiotek 100 - The ultimate reference screen, no sparkling. Low Gain.
Aspect & Size
I don't own a lens currently, but I have seen more and more affordable stuff out there.
16:9 - Thinking of 100" - 106".
Scope - Thinking 110".
Please tell me what you think.
post #102 of 507
For anyone using Atlona baluns. Atlona recommends using cat-7, then cat-6, then cat-5. We ran audioquest brand Cat-6 and attempted to terminate with several brands of cat-6 tips. Could not get the baluns to work with EZ-RJ45-cat6 ends or ideal (home depot) brand cat-6 ends and would only work with poor quality picture using monoprice cat-6 ends. I tried ideal (home depot brand) cat-5 single piece tips and worked immediately and with excellent results.
post #103 of 507
Awesome work. Easily my favorite build thread
A+
post #104 of 507
A+
Thanks, much appreciated.
post #105 of 507
Office TV is complete. Wire termination and management takes sooo long.
post #106 of 507
These are the baluns that are behind every TV.
post #107 of 507
I also mounted my computer monitors. Still need to run all the wires. Nice to have an office kind of put together.
post #108 of 507
post #109 of 507
Family Room is still under construction. Need to get some help to lift the TV down to re-terminate the baluns.
post #110 of 507
I normally don't like TVs above fireplaces, but you can see from this picture that the family is open to the kitchen and we like to watch the news while we cook/ eat/ clean.
post #111 of 507
Well its been slow going lately. I've been working long hours on this project, but the rack has been incredibly time consuming. I spent a whole day on routing power. 2 days on terminating, labeling, and heat shrinking the cat-6 lines only within the rack. There are 23 data lines within the rack. This does not include the data I still need to bring into the rack from the wires that go to other areas of the home. I am going to need another switch. Ugh...... I would love to find a 48-port that is a little quieter than my 24. Lastly, I got the HDMI's run in the rack. I still have to do speaker wires, comm (RS-232 and IR) lines, component video, composite video, stereo audio lines, balun lines. Would love to be finished with this thing by the end of the weekend.
Ugh......
post #112 of 507
This is the number of analog lines in the system. (32) pairs.
post #113 of 507
I've been stalled for a few hours trying to find a good source for RS-232 pinout and conversion. I am using the tips pictured above for Rs-232 lines between the controllers and the equipment. Uses a cat-5, which allows termination to length.
To build an 8-wire RS232/RS485 serial cable for use with the Nema-4 enclosure, use a standard CAT-5 networking cable to act as the extension between the computer and the radio modem. (This cable will be carrying RS232 signals, not ethernet signals.)
Assemble both the yellow and green adapter according to this table:
DB9 pin RS-232
Signal Name RS-485
Signal Name Wire color
(Adapter) RJ45 pin # Wire color
(Ethernet cable)
1 DCD Orange 2 Orange
2 RXD TX- Red 4 Blue
3 TXD RX- Yellow 6 Green
4 DTR Blue 1 White/Orange
5 GND GND White 8 Brown
6 DSR - - -
7 RTS RX+ Black 3 White/Green
8 CTS TX+ Green 5 White/Blue
9 PWR(RI) PWR* Brown 7 White/Brown
When the adapters are assembled, test the cable by attaching the loopback plug into the yellow adapter and the CAT-5 cable, and the green one into the PC and the CAT-5 cable.
Use the loopback test in the X-CTU software to determine that packets can be transmitted correctly.
Remove the loopback adapter and attach the radio modem.
This is a great link!
http://www.digi.com/support/kbase/kb...tdetl.jsp?kb=3
post #114 of 507
http://www.firgelliauto.com/default.php?cPath=104
These are pretty cool. I will end up using one to make the automated lens slide for the projector in the media room. I have decided on a 115" 1.35 scope screen from Stewart.
post #115 of 507
Nice find - could be a good option for floor-to-ceiling masking on a CIH screen? Hhhmmmm, interesting!
post #116 of 507
Well I made some more progress this weekend. Here are some photos.
post #117 of 507
This is the theater. I have decided on a CIH system. My wife told me I could either have some Martin Logan Ethos speakers or the lens for Christmas. Going for the speakers. Lens will come with the construction of the theater.
post #118 of 507
The parts shelfs are looking more and more empty.
post #119 of 507
The rack is half way running.
post #120 of 507
This was a pain. Made all these wires still need to zip tie.
