AVS › AVS Forum › Video Components › Home Theater Computers › Advanced MPC-HC Setup Guide
Advanced MPC-HC Setup Guide - Page 56
post #1651 of 1929
I just move the mouse up into the corner and it disappears...
im not sure about the menu displaying under the media player.
Try to launch MPC HC stand alone and see if you have those issues.
post #1652 of 1929
I turned off subtitles in LAV Splitter but they still show up in the movie. What should I do frown.gif
post #1653 of 1929
Roll back to a nightly build before 1.6.6.6538.
post #1654 of 1929
That means MPC still has them on, right click, subtitles, click enable subtitles to that it's turned off.
post #1655 of 1929
There is a bug in recent MPC builds that overrides LAV splitter settings when LAV disables subs if they are not needed and MPC shows them anyway. nev has isolated it to builds after 6538 and pointed it out to the MPC team. The MPC developer appears to be in no hurry to fix it.
post #1656 of 1929
This is why I don't update. I've been running the same version of MPC-HC, LAV and madVR for over a year, almost two actually, and don't have any problems. That said, I'd like to upgrade if there's a compelling reason to do so.
post #1657 of 1929
Try to launch MPC HC stand alone and see if you have those issues.[
When I load it stand alone I still have the issue with the mouse but I can access the menus with a right click, it also displays the mpc hc window. With the stand alone player software can also hide my mouse but as an external player the mouse is still visible.
Edited by josh_parker123 - 2/1/13 at 1:36pm
post #1658 of 1929
Josh...
Did you put this command line in the media browser settings?
"{0}" /fullscreen /close
look at this post
http://community.mediabrowser.tv/permalinks/2086/mpc-hc-external-player-tips-tricks
scroll to the picture where you see configure external player... in the optional parameters you should put this:{0}" /fullscreen /close
make sure you do it exactly with no extra spaces etc... do not cut and paste type it so you are 100% sure
Edited by fschris - 2/2/13 at 6:01am
post #1659 of 1929
i dont understand the output of ffdshow audio
in the input it says: Dolby true HD 6759 Kpbs
the out put is: HDMI Bitstream 1402
I never see the Dolby True HD light up on my RCVR. Should I not output the same as the input?
I am using the Intel HDMI Audio Driver and I am using the Asrock H67m Core I3 MB
I have the HTPC connected to the RCVR via HDMI and the ouput of RCVR HDMI to plasma.
in MPC-HC i have all the pass through DTS, TRUE HD ticked.....
Edited by fschris - 2/2/13 at 7:40am
post #1660 of 1929
Originally Posted by JDLIVE View Post
I'm having the same issue, when MPC-HC launches from Media Browser, the movie is paused. I can just hit play and it'll start, no need to exit full screen mode. Not a big deal, seems to have started with the recent MadVR version.
This is no longer a problem for me, no changes made so not sure what the cause was. Maybe just a reboot needed?
post #1661 of 1929
Can LAV Bitstream pcm? I had Disney's Cars playing on mpc but my amp only showed dolby pro logic. frown.gif
post #1662 of 1929
There is no such thing as "bitstream" for PCM. Bitstreaming is only for compressed formats, PCM is not compressed.
post #1663 of 1929
Anthony, how are your speakers set up in windows? If they are set to stereo, you won't get multi channel PCM on your receiver. Sounds like your receiver is getting stereo and applying pro logic to it.
post #1664 of 1929
Will an I3-2120T be fast enough for MPC-HD with reclock and everything else?
post #1665 of 1929
They were set to surround....
post #1666 of 1929
My reciever is odd... it never changes the display on the front to Dolby True HD, DTS, PCM, LPCM no matter what format the decoder says it is outputting... it always just says 'PC'. This annoys me so much.
post #1667 of 1929
That does seem odd, do you have a PC input? I think when I use HDMI ARC on my receiver (RX-V667) it says TV as the input but it will still show the codec or PCM. From my PC it usually shows PCM unless a movie is playing back and bitstreaming (via HDMI) then it will display whatever encoding the audio track is.
post #1668 of 1929
AFAIR, albain tried to implement bitstream for LPCM tracks (and found he needs to swap endian after splitter).
post #1669 of 1929
LPCM is just plain PCM in big-endian. Once you swap that to little-endian, its exactly the same as plain decoded audio, so there is simply nothing to bitstream.
Bitstreaming is about passing compressed audio to the AVR, but LPCM is not compressed, so this does not apply. There is simply no standard for "bitstreaming LPCM", because LPCM is just uncompressed PCM, you can already pass that over HDMI without any difficulties. If you want to "bitstream" LPCM, just get a WASAPI audio renderer in exclusive mode, sit back and enjoy.
post #1670 of 1929
I assume there is just no other option to pass LPCM over windows audio mixer untouched but to force player to use WASAPI Excl somehow. I mean media streaming apps are often limited in that point.
BTW, is it possible to bitstream DTS-HD with fake DTS header? I mean if you can pass DTS with WAV header, why not fool same way S/PDIF or XP's sound system with DTS-HD for example?
post #1671 of 1929
DTS-HD has a too high bitrate to fit into a normal DTS stream, which means the audio device needs to handle it differently to have enough room, and that needs driver/audio renderer support.
Not to mention that the receiving device would most likely not understand what you're sending it.
post #1672 of 1929
Hi All.
WOW, this is a HUGE thread!
I am using Win7 Ultimate MCE. From there I use Media Browser to manage my collection. All my rips are the complete disc in the original folder structure (basically a 1-for-1 copy). After selecting a movie, MB uses MPC-HC (was using TMT5, but certain Blurays don't play well with TMT5; Hence the switch to MPC-HC). MPC seems to launch the movie directly, skipping over all the trailers and menu. This is fine in the majority of cases, but I have not figured out how to get to the main menu of a disc with MPC. I cannot select any of the additional feature on the disc. Some discs (Daybreakers for example) only play the features and NOT the movie???? And since I cannot seem to access any sort of menu in MPC, I cannot actually watch the movie in those cases.
Any suggestions?
post #1673 of 1929
MB3, due in April is supposed to fix this for you/us.
post #1674 of 1929
OH, so it is actually a known bug/issue?
Here I thought it was just me not being able to find the right combo of options......
Is there any sort of temp workaround? Are there any links or search criteria to read more about Media Browser 3?
THX!!!!!
post #1675 of 1929
About MB3: http://community.mediabrowser.tv/permalinks/13138/introducing-media-browser-3
Just note that it won't magically give you access to the Blu-ray Menu, it will just add the special features to its own navigation.
post #1676 of 1929
AH. TY for the link.
SO, is there ANY way now, or in the foreseeable future to access a Bluray menu with MPC-HC ?
post #1677 of 1929
Everything I've read says a retail software is required if you want BD menu access. I didn't know MPC could access special features on BD either.
post #1678 of 1929
Some people enjoy thumbing through menus, watching special features, FBI warnings and trailers before they can watch the movie. I OTOH do not have time for this and am happy to watch just the movie.
post #1679 of 1929
Like you sammy I don't want access to those either.
However for rms8, he might want to try xbmc (I believe it provides access to all playlists on a full disc rip, which although not identifying the actual list by name, does give the option to choose something other than the main movie). Not ideal but better than no access at all.
post #1680 of 1929
The best choice for that is using a stand alone Blu-ray player. My circa 2007 Samsung BD-P2500 is in standby just an activity click away on my H-900 remote. It is lonely though, only getting used once a month or so.
