Thank you for the guide. I followed the step and the videos quality improved quite a bit. I have a bit of trouble with the audio though. I did everything in the step correctly but i have no sound at all.
My setup is:
i5 - 2500k
6950 HD
Xfi Titanium
I run an SPDIF cable from my sound card to the receiver, which is set for DTS mode. I tried few file with ac3 and i have no sound at all. I tried to disable lav audio filter and use the default. I can hear sound but not 5.1. I used ffdshow before i did a fresh windows re install and have 5.1 surround fine, would lav filter improve the quality? (I also have TMT for the dts-hd) If it does then how would i fix this problem?
edit: I tried ffdshow again and only there sound only when the output is stereo and nothing when set to 5.1
another thing i am confused is the transform filter in "internal filter" is the rest of filter in transform filter box suppose to be check or un check?
My setup is:
i5 - 2500k
6950 HD
Xfi Titanium
