AVS › AVS Forum › A/V Control & Automation › Remote Control Area › vizio, IRtoy, and WinLIRC
post #1 of 3
Greetings,
I am seeking information (two byte IR codes) to control my vizio tv with my pc, particularly when it is not displaying the pc screen.
I have an IRtoy, its cool. I am using WinLIRC to control it.
(WinLIRC info at sourceforge)
(IRtoy info at dangerousprototypes)
The combination is working fine. All the functions in the config work. I want to add more functions. For instance, the tv has 3 hdmi inputs, I have a code that selects HDMI-side, but none for HDMI 1/2.
I have JP1 information for a Vizio SV472XVT with discretes. The single byte function codes match the last byte of my IRtoy function codes.
How do I find that first byte? Or How do I find the 2-byte codes I need from some other format?
Here is the WinLIRC config content I am using now:
begin remote
name Vizio
bits 16
flags SPACE_ENC
eps 30
aeps 100
header 8966 4400
one 567 1596
zero 567 494
ptrail 575
repeat 9000 2194
pre_data_bits 16
pre_data 0x20DF
gap 40403
repeat_gap 95450
toggle_bit_mask 0x0
begin codes
Guide 0x38C7
AV 0x8A75
COMP 0x5AA5
HDMI 0x639C
TV 0x6B94
RGB 0x19E6
UP 0xA25D
LEFT 0xE21D
DOWN 0x629D
RIGHT 0x12ED
MENU 0xC23D
MUTE 0x906F
LAST 0x58A7
VOL_UP 0x40BF
VOL_DWN 0xC03F
CH_UP 0x00FF
CH_DWN 0x807F
ONE 0x8877
TWO 0x48B7
THREE 0xC837
FOUR 0x28D7
FIVE 0xA857
SIX 0x6897
SEVEN 0xE817
EIGHT 0x18E7
NINE 0x9867
ZERO 0x08F7
INPUT 0xF40B
DASH 0xFF00
POWER 0x10EF
end codes
end remote
Here is JP1 Data for Vizio SV472XVT, this seems to have the discrete codes I want, but only the last byte...
Description=Vizio SV472XVT with discretes
Remote.name=URC-8800 Producer 8
Remote.signature=HUD0HUD0
DeviceType=TV
DeviceIndex=2
SetupCode=758
Protocol=00 5A
Protocol.name=NEC1
ProtocolParms=4 null null
FixedData=00 DF DF
Function.0.name=0
Function.0.hex=F7
Function.1.name=1
Function.1.hex=77
Function.2.name=2
Function.2.hex=B7
Function.3.name=3
Function.3.hex=37
Function.4.name=4
Function.4.hex=D7
Function.5.name=5
Function.5.hex=57
Function.6.name=6
Function.6.hex=97
Function.7.name=7
Function.7.hex=17
Function.8.name=8
Function.8.hex=E7
Function.9.name=9
Function.9.hex=67
Function.10.name=vol up
Function.10.hex=BF
Function.11.name=vol down
Function.11.hex=3F
Function.12.name=Audio
Function.12.hex=2F
Function.13.name=MTS
Function.13.hex=AF
Function.14.name=mute
Function.14.hex=6F
Function.15.name=mute OFF
Function.15.hex=7B
Function.16.name=mute ON
Function.16.hex=FB
Function.17.name=power OFF
Function.17.hex=5B
Function.18.name=power ON
Function.18.hex=AB
Function.19.name=channel up
Function.19.hex=FF
Function.20.name=channel down
Function.20.hex=7F
Function.21.name=device power toggle
Function.21.hex=1F
Function.22.name=power
Function.22.hex=EF
Function.23.name=skip rev
Function.23.hex=8B
Function.24.name=cancel
Function.24.hex=2B
Function.25.name=enter
Function.25.hex=00
Function.26.name=last
Function.26.hex=A7
Function.27.name=comp 2
Function.27.hex=B1
Function.28.name=menu
Function.28.hex=3D
Function.29.name=guide
Function.29.hex=C7
Function.30.name=info
Function.30.hex=27
Function.31.name=OK
Function.31.hex=DD
Function.32.name=up arrow
Function.32.hex=5D
Function.33.name=list
Function.33.hex=47
Function.34.name=down arrow
Function.34.hex=9D
Function.35.name=left arrow
Function.35.hex=1D
Function.36.name=right arrow
Function.36.hex=ED
Function.37.name=comp 3
Function.37.hex=31
Function.38.name=comp 4
Function.38.hex=D1
Function.39.name=HDMI 4
Function.39.hex=DE
Function.40.name=wide
Function.40.hex=11
Function.41.name=HDMI 5
Function.41.hex=5E
Function.42.name=HDMI 1
Function.42.hex=7E
Function.43.name=HDMI 6
Function.43.hex=9E
Function.44.name=HDMI 2
Function.44.hex=BE
Function.45.name=HDMI 7
Function.45.hex=1E
Function.46.name=HDMI 3
Function.46.hex=3E
Function.47.name=RGB
Function.47.hex=E6
Function.48.name=AV 1
Function.48.hex=7A
Function.49.name=sleep
Function.49.hex=8F
Function.50.name=pip
Function.50.hex=F9
Function.51.name=pip size
Function.51.hex=79
Function.52.name=pip input
Function.52.hex=B9
Function.53.name=pip ch -
Function.53.hex=39
Function.54.name=pip ch +
Function.54.hex=D9
Function.55.name=pip swap
Function.55.hex=99
Function.56.name=pip pos
Function.56.hex=19
Function.57.name=play
Function.57.hex=33
Function.58.name=pause
Function.58.hex=13
Function.59.name=rewind
Function.59.hex=53
Function.60.name=skip fwd
Function.60.hex=B3
Function.61.name=stop
Function.61.hex=F3
Function.62.name=replay
Function.62.hex=73
Function.63.name=record
Function.63.hex=D3
Function.64.name=fwd
Function.64.hex=93
Function.65.name=pause/step
Function.65.hex=E3
Function.66.name=CC
Function.66.hex=63
Function.67.name=zoom +
Function.67.hex=FD
Function.68.name=zoom -
Function.68.hex=7D
Function.69.name=exit
Function.69.hex=6D
Function.70.name=back
Function.70.hex=AD
Function.71.name=search
Function.71.hex=2D
Function.72.name=AV
Function.72.hex=75
Function.73.name=yellow (A)
Function.73.hex=B5
Function.74.name=blue (B)
Function.74.hex=35
Function.75.name=red (C)
Function.75.hex=D5
Function.76.name=green (D)
Function.76.hex=55
Function.77.name=comp
Function.77.hex=A5
Function.78.name=setup
Function.78.hex=CB
Function.79.name=input
Function.79.hex=0B
Function.80.name=5.1 audio
Function.80.hex=09
Function.81.name=comp 1
Function.81.hex=71
Function.82.name=pip freeze
Function.82.hex=59
Function.83.name=HDMI 8
Function.83.hex=EE
Function.84.name=AV 2
Function.84.hex=BA
Function.85.name=AV 3
Function.85.hex=3A
Function.86.name=AV 4
Function.86.hex=DA
Function.87.name=HDMI
Function.87.hex=9C
Function.88.name=TV Input
Function.88.hex=94
Function.89.name=media
Function.89.hex=F0
post #2 of 3
The first byte and the second byte add to 0xFF.
For example, your LIRC listing has
Guide 0x38C7
AV 0x8A75
COMP 0x5AA5
HDMI 0x639C
So from the JP1 file, HDMI7 is 1E. In LIRC that is
0xE11E
post #3 of 3
That works.
Thank you very much. Restores a little faith in forums.
  Back to Forum: Remote Control Area
