AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread
The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread - Page 2
post #31 of 2479
Originally Posted by bogiedr View Post
I recently packed up a brand new Aventage 700, (still has two year warranty), going to the closet because I hate the audio section. The Integra 20.3 that replaced it automatically plays what it is supposed to, (Dolby DTS, whatever the right coding is), and it displays it. The Yamaha will not tell me what it's doing. I'd love to use the 700 as a pre amp, but how do I set it up so it tells me what mode it is playing in?? I like seeing the amp move from one mode to the other, it assures me it is working correctly. Am I nuts here??
Hit the info button on the remote and it will tell you what codec it is using.
post #32 of 2479
One change between the 3000 and 3010 is that if you are running 11.2 then on the 3000 you could only use external amp on front and rear presence speakers.
The 3010 you can use a higher quality external amp for front L and R. And use 3010 to power rest.
Thie 3010 is great when using a 2ch external amp with HT bypass to power your fronts for discrete listening.
post #33 of 2479
can anyone post any manual eq settings ...I need a reference point for my 3010 to play around with...
post #34 of 2479
Originally Posted by frooky View Post
A comfortable listening level on my 710 is between -35 and -45 depending on source material. I have my receiver's default volume set to -50 when it turns on just so I don't wake the kids if I want to watch the news before they wake up but even then sometimes I have to turn the volume down to -55 depending on the channel. That's a pretty wide gap but I hope that gives you some idea as to how much the source material/signal effects volume level. Also I am using klipsch bookshelf speakers with 5-1/4" woofers on the mains and 4-1/2" woofers on the surrounds all about ten feet away from the calibrated spot. You might also play with your dynamic range settings. I find that standard is much quieter than maximum or minimum/auto for some reason.
I agree -35 is comfortable for me -30 is about is a work out for my ears ...I still use saving private ryan opening scene on the beach as my bench mark -30 is ear candy for the 3010 ..must say I love the 3010
post #35 of 2479
bump ..transformer dark side of the moon no true hd or 7.1 surround ...put in Iron man bd and low and behold true hd lit
up my yammi 3010 ..happy days or here again
post #36 of 2479
Hit the info button on the remote toggles between DSP mode and HD codec mode. Hitting DSP straight disables Yamaha's DSP's and only uses the HD codec
as per BR disc.
post #37 of 2479
I think somethings wrong with the disc..the blue ray light on my sony bdps350 doesn't come on on this disc..in the menu it shows 5.1 dolby digital english
post #38 of 2479
Originally Posted by rdgrimes View Post
Asked almost weekly. the db display on different AVRs is relative, it's not a real measurement of levels. -20 is a very normal listening level for the recent lines of Yammie AVRs. YPAO sets your level so that "0db" is near to "reference" levels. And, this model goes to +16db, where others stop at "0".
Interviewer, off camera: "Why not just make 0 louder, and have that be the highest level?"
Pause
Yamaha engineer: "Ours go to +16"
Apologies to Spinal Tap...
Greg
post #39 of 2479
I just ordered a 710 to replace an H/K 254 that the HDMI died. I hope this sounds as sweet as the H/K did, but I wasn't going to spring for another and worry about it going south in a couple years again. Has anyone played both and have an opinion on the SQ difference between Yamaha and Harman Kardon?
post #40 of 2479
post #41 of 2479
the yamaha 3010 has opened up a whole new world of sound for me my speakers have come alive with sound ..I'm using a 7.1 system no back surround but I'm using presence speakers ..Several post have said their is no need for them but they do add to the mix ..not sure when playing a blu ray true hd does the bd player do the decoding or does the reciever do the decoding ..one thing lacking on this reciever is a line in for my creative juke box ..doesn't recognize the player through the usb port
post #42 of 2479
After much consideration, I purchased the A800 last night to replace my rx-v3200. Sad to see the old loyal guard regulated to the garage, but it can't delay audio for lip sync, no HDMI, nor can it deliver the newest sound codecs. In its day the 3200 would squash this 800. LOL
What I found strange is that of the A700, A710, A800, A810, only the A710 doesn't have pre-outs. My system uses a dedicated amp for the mains, and I almost bought the A710. It just hit me as weird. No biggie if you don't need the pre-out option.
post #43 of 2479
I upgraded to the 2010 coming from a 3900.
So far so good. Added front presence and soon a 2nd sub. ANyway. No receiver manager?
Anyone know when this will be able to be updated to OUR models? ALso....can't connect to my PC. Have not trouble w/ Net radio or Sirius.
Kdog.
post #44 of 2479
Originally Posted by MichaelJHuman View Post
I added a comparison list like I have done in the past, hope you don't mind.
Assume it has mistakes (and message me if you see any, will correct ASAP.)
[Jack counts show input and output as input/output]
Common Features
* "Advanced" On Screen GUI
* HDMI 1.4 Supporting 3D with Audio Return Channel; At least 6 HDMI inputs (including front panel)
* HDMI Standbye
* Analog to HDMI Conversion
* Analog and HDMI upscaling to 1080p (With edge adaptive deinterlacing)
* Front panel AV aux jacks and HDMI Jack
* YPAO (Auto setup and room correction)
* Network audio including Pandora, Rhapsody and Napster
* Sirius/XM
* iPod/iPhone connectivity with optional dock
* Multi-zone (At least one secondary zone)
* Front USB Input
* Component Video Jacks - 2/1
* Composite Video Jacks - 5/1 (Including front panel jack)
* 2/0 Optical S/PDIF (Digital audio)
* 2/0 Coax S/PDIF jacks (Digital audio)
* Stereo Analog jacks - 5/0
* Headphone output
* Low power standbye (Only 2 watts with HDMI standbye)
* Auto shutdown (Based on a user selectable timer)
* +12 volt amp trigger
[NOTE : Under additional features, assume higher models encapsulate additional
features from lower models (to avoid repeating information)]
RX-A710
- MSRP 650
- 23.6 pounds
17-1/8"x6-3/4"x14-1/2"
** 7.1 (7 amps, one sub out)
** Rated Output Power (1kHz, 2ch driven) 105W (8ohms, 0.9% THD)
** Rated Output Power (20Hz-20kHz, 2ch driven) 90W (8ohms, 0.09% THD)
RX-A810
- MSRP 850
- 24.5 pounds
** 7.2 (7 amps, 2 sub outs)
** Rated Output Power (1kHz, 2ch driven) 110W (8ohms, 0.9% THD)
** Rated Output Power (20Hz-20kHz, 2ch driven) 100W (8ohms, 0.09% THD)
-- Additional Features
* Multi-point YPAO
* 8 HDMI inputs; 2 outputs
* 8 Channel Pre out (For connection to external amps(s)
* Party Mode
* RS-232C Interface
RX-A1010
- MSRP 1100
-33.3 pounds
17-1/8 x 7-1/8 x 17
** Rated Output Power (1kHz, 2ch driven) 120W (8ohms, 0.9% THD)
** Rated Output Power (20Hz-20kHz, 2ch driven) 110W (8ohms, 0.06% THD)
* HD Radio
* Zone 2 output includes video output
* Front panel optical and S-Video inputs
* +2 Optical inputs; +1 optical output ( 4/1 total)
* +1 Digital coax input ( 3/0 total)
* +5 Stereo analog inputs ( 10/1 total)
* +2 Component video jacks ( 4/1 total)
* S-Video jacks - 5/1 (Including one front panel input)
* Multi-channel input (For SACD player with analog jacks, DVD Audio player, or multi-format player)
RX-A2010
- MSRP 1600
- 37.7 pounds
17-1/8 x 7-1/2 x 18-3/8
** 9.2 (9 amps, 2 sub outs)
** Rated Output Power (1kHz, 2ch driven) 155W (8ohms, 0.9% THD)
** Rated Output Power (20Hz-20kHz, 2ch driven) 140W (8ohms, 0.06% THD)
* More DSP modes (23 vs 17)
* YPAO with "Reflected Sound Control"
* Video adjustments (Such as brightness)
* Subwoofer remote control
* Third zone; GUI for Zone (With video connection for zone I assume?)
RX-A3010
- MSRP 2000
- 40.1 pounds
** Rated Output Power (1kHz, 2ch driven) 165W (8ohms, 0.9% THD)
** Rated Output Power (20Hz-20kHz, 2ch driven) 150W (8ohms, 0.06% THD)
* YPAO with "Reflected Sound Control" and Angle Measurement
* 11.2 channel pre outs
* 4th zone with optical
* Backlit remote control
Nice to see you again michael, you have helped me in the past w/ me 3900. I upgraded to a 2010
post #45 of 2479
+1
Glad you find the presence worthwhile. I am going 9.1 soon. The Yamaha DSP
programs create the sound in the presence speakers. hitting 3D sound to on
(Options button) improves the effect even more.
I have been upgraded to a 3010 frm a 3000 due to a missing remote (small one). The 3000 was good but I believe after listening to my reference track "opening sequence" of the BluRay Outlander I felt my jaw hitting my chest. I have never heard it sound this good before.
A lot has been said about the upgrade of YPAO on last years version. The clarity and dynamic sound is something I was searching for.
Just love my new 3010
post #46 of 2479
I've got the A710 on my "short list" and have a question for current owners.
How does it fare as far as operating temperatures goes? This is a class AB unit, right? Does the unit have active fans?
See my thread here for the short list: Help me move out of the stone age
post #47 of 2479
I have not noticed mine getting very hot, I don't think it has a fan just convective cooling. I just wish I would have gone with the A810 because I wanted preouts and thought the A710 had them
post #48 of 2479
2 problems Im having. Can't stream PC content.
Can't use old version of receiver manager w/ this new 2010.
Stream is set to all devices on windows 7 . Can't figure it out. Need help.
post #49 of 2479
ru wired or wireless...window 7 gave me a promlem but i have a linksys router using network magic ..don't forget that u have to setup your music folder to share with eveyone....networking is tricky
post #50 of 2479
JAZZ.. Wired. RIght to my linksys router. Can use Sirious IR no problem and can use NET rADIO no problem. Just can't access my PC.
Do you have receiver manager?
post #51 of 2479
jazz...do I have to setup something on my Receiver. My folders on windows 7 are set to allow devices to access pictures and videos and what not.
post #52 of 2479
c;/documents/users/your name /my music..
or windows media player playlist load your song there then see if they show up on your tv interface
post #53 of 2479
Jazz and Con,
Can you elaborate further on how the Presence Speakers have added to the "Experience"...?
Also what does turning ON the 3D Options Button further add to the already added "Experience"...?
Rana
post #54 of 2479
how do I rename the inputs. I have tried everywhere on the OSD and can't find Input rename?
post #55 of 2479
Press "On screen" button. In the left menu go to "input" then select the input desired and press ^ cursor. Then select "rename/icon select"
post #56 of 2479
Thanks. Never realized to press up on the curser....duuugh.....
THanks
Kyle
post #57 of 2479
Posted as its own thread earlier, but thought I would post here too:
Staring at a box just delivered for a Yamaha RX-A2010. First new receiver in a while... Old stuff was in a fire several years back and had never replaced it.
Mostly for movies and games. Could have had a TX-NR1009 for about $120 cheaper. Will I miss NEO:X and some of the other modes for movies for 7.1 or 9.1? I have read mixed reviews on the Yamaha proprietary surround processing.
The recent reputation for reliability with Onkyo scared me away, but now I am already hearing the new models do not run nearly as hot.
Either receiver though is far and away higher end than what I had previously as a college student.
What do you think?
post #58 of 2479
Question for RX-A2010 or 3010 owners.
I have a Salamander Archetype system and the shelves are 16" deep. I'm trying to see if the receivers will fit on the shelf. The shelves are an open design. http://www.salamanderdesigns.com/products/av.jsp
What is the distance between the front of the front foot and the back of the rear foot of either of these receivers?
post #59 of 2479
my shelve is 16 inches the feet are about 14 inches outside to outside the box is about 8 inches high so it will fit but overlaps front and back
post #60 of 2479
That will work great!
