AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread
The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread - Page 32
post #931 of 2469
Yapo question.
When setting it up this one of the steps.
"The crossover frequency controls of the connected subwoofer is set to maximum"
My dumb question is that if you are using the LFE output then the crossover function on the subwoofer is usually set to off.
Am I reading this right?
post #932 of 2469
Originally Posted by G42 View Post
Hey all. I just got an RX A810 a couple of weeks ago and I'm having a couple of problems I was wondering if anyone has an easy fix for. Me being an idiot is a lot easier than having to send the damn thing back.
First of all, when I put anything at all in the usb port on the front, all I ever get is "Access Error" and then "No Content". The devices I'm plugging into it work just fine anywhere else.
The second issue is that everytime I turn the unit on, about 10-20 seconds later it automatically switches to AV4 for no apparent reason. I don't have anything connected to AV4 and never have. Even if I switch to the channel I want as soon as I power on, it will always switch to AV4.
Any ideas or should I send it back?
Do you have hdmi control activated via hdmi using arc? My 3010 would do this if I tried to use arc with my Samsung d8000. Sammy broke compatibility and I cannot use arc.
The ony device I know that works with the USB is an iPod/iPhone. The iPad doesn't work nor does anything android.
post #933 of 2469
Originally Posted by rustolemite View Post
Yapo question.
For your sub, set the freq. noob to max and the volume noob to half before you start YAPO. Make sure your phase is at 0°
I always go back to the manual setup after and change all speakers to Small and the bass crossover to 80hz.
post #934 of 2469
Hey thanks for you input, will do just that.
And like your sig about the Onkyo, I had one but that sucker just would not work right with my Mits tv.
Been happy with my Yammy's ever since.
post #935 of 2469
The big deal about the A3010 is its 4 zones (primarily among other things) right? Yet Yamaha puts both the Zone and Party functions under the flap on the remote as if they are obscure functions. That is beyond stupid. I use these almost every single time I use the receiver.
Only other complaint is the sound of this thing is just so amazing, I cannot stand to listen to music in my car anymore.
post #936 of 2469
lol
post #937 of 2469
agreed
post #938 of 2469
They probably put party function behind a flap so you don't push it accidentally and disturb whoever is in the other zones.
post #939 of 2469
When I got my first Yammy I hit that button by accident and didn't know what it did and it took me 2 hours to figure it out !!!
post #940 of 2469
I want to thank you for that. I ran YPAO and got :error W 3. I'll run it again later this afternoon.
You've probably saved me some grief.
Thanks again!
post #941 of 2469
Originally Posted by Scarriere View Post
I I ran YPAO and got :error W 3. I'll run it again later this afternoon.
Make sure your sub is ON and not on Auto ON. If it was ON I guess you'll to turn the Vol. on the sub up a bit and try again. I've never had that problem.
post #942 of 2469
So help me out here. Am I just the unluckiest guy ever or are these Yamaha receivers lacking quality control?
I have gone through 2 defective units now. I'll have to speak with my dealer to have this last one replaced again I guess. Jesus christ.
Have a look at these images: http://imgur.com/a/lF6bK
post #943 of 2469
WOW! You are the unluckiest guy ever! I went with Yamaha because I've heard they are one of the best built and longest lasting AVR's out there. Maybe your dealer is selling blem's for a better markup or something? I would probably return it and get one or something else at other dealer.
post #944 of 2469
Curious about where your dealer is fulfilling his stock from. Those look to be signs of bad shipping practices to me.
post #945 of 2469
They are fresh out the box. The box has not been opened before and the most recent receiver was driven in a car home to me. It was delivered to me in person at the door step. Looked to have no damage what so ever.
Too bad it's the weekend now, I won't get an answer until monday...
post #946 of 2469
Are you using a USB stick? If I understand the manual correctly, non-HDD USB devices must be FAT 16/32 file system.
post #947 of 2469
Hi, I have my 2010 for 2 weeks now, but i can't seem to find an option where i can set the frequency for the speakers. My old Denon had that feature.
So if i want to cut the speakers off at 80hz, i have to set them to small?
That's really weird...
post #948 of 2469
Simple, using your remote, select onscreen... Setup then navigate to speakers. Choose manual and you will see all of the changes you can make, including the size and freq of each speaker.
post #949 of 2469
That bugged me too coming from Audyssey to YPAO. The only thing you can do is after YPAO go to manual setup and change all speakers to Small and set your Bass Crossover to 80hz. You can't do each speaker at a different hz. That's how my A810 works...don't know if it's the same on a 2010?
post #950 of 2469
On the 2010 you can set each speaker's hz. I did that this afternoon. YPAO set all of mine to large, which I then changed to small, along with the cross over.
post #951 of 2469
Very cool, I guess the OP just has to go to manual setup to see that.
post #952 of 2469
Yup! Or just come here.
You guys are pretty helpful and I appreciate that!
These new Aventage AVR's are (to me) fairly complex and it's great to get advice here and there.
Cheers Dude!
post #953 of 2469
Got the a710 hooked up last night and manually set up every thing. Sounds kinda thin compared to my Marantz SR5500 I came from. Wondering if its because of the high current with the Marantz? I assumed the Yammie's where high current, but no where in the literature does it say. Well any ways I dont think its suppose to sound this thin and lean. What about that automatic set up with YPAO? Can it do what I cant do? For the front speakers I run to Paradigm Monitor 7 v'3 towers. These are not the little Monitor 7's Paradigm build now, but the big towers before they went smaller. My rear speaker are also big tower, Klipsch M4's. I did use a 125watt Adcom amp with the fronts on the Marantz, but even without the amp the Marantz was still more dynamic than the Yammie is now. So has anybody experienced this as well? I would hate to pack it all up and send it back. But I have no problem getting a new Marantz but wanted to save a few $$$.
post #954 of 2469
Originally Posted by eagle2 View Post
I own a Onkyo TX-NR808. Purchased January 2011. Last week, the second week in April 2012, it started to exhibit some of the problems listed in these forums regarding the audio.
Mine showed up in the center channel, it sounded mushy and then the sound was reduced to almost nothing. When I tried to adjust the unit it would shut off.
I tried to contact the Onkyo service department in New Jersey. I tried three different days and was always on hold and never got to speak to anyone. My guess is that my total hold time was something on the order of an hour or so. When I tried to follow their instructions to leave a message so that they could return my call, nothing happened. I punched the star key on my phone, as required, and was never able to reach a recording device.
In the past I have always purchased Yamaha equipment and had been very pleased with it. This goes all the way back into the 1960s. I have their top level amp preamp combination and it has never failed me. But by the time we got to HDMI I thought I would try another device. So I purchased a Denon receiver. I really like the receiver but the remote was terrible. So having read all kinds of good things about Onkyo, and the extra features for less cost, I thought I would give them a try. And I have been relatively satisfied with my 808 until last week as mentioned above. I must say their customer service is pathetic. I found on there web site where the authorized service center for my part of the country was. It is ABL Electronics Service in Michigan. I contacted them and they told me that they were very backed up since there were only two authorized service centers in the United States for Onkyo. But it would probably cost me $40 or $50 to ship the receiver to them(they were right cost $45.00). They told me that it would probably take at least three weeks to service the unit and return it to me.
I will never purchase another Onkyo product.
So I went out and bought another Yamaha receiver, model RX-A710. It sounds great right out of the box!
unfortunately it does not come with a printed users manual. I found out from reading the Yamaha section in the excellent AVS forums that if I would call the Yamaha customer service department I could receive a printed manual for free. So I proceeded to call them. I receive the kind of excellent customer service from Yamaha that I had hoped to receive from Onkyo, and did not.
Onkyo needs to take a lesson from Yamaha. I am back with Yamaha products now and do not intend to stray again!
Can you tell me what number to call? I just purchase the same RX-A710 and have been using the soft copy, but wold rather have a hard copy.
post #955 of 2469
Thank you very much everyboday for the help !!!
post #956 of 2469
I'm having the same problems on my 1010 with the strange characters showing up on the display. Only happens occasionally and everything else works fine.
post #957 of 2469
That's very unfortunate. I've dispatched a email to my dealer, they'll get back at me on monday I reckon. I've had so much trouble with this receiver... damn
post #958 of 2469
Go here.
http://usa.yamaha.com/support/parts_manuals/
post #959 of 2469
Ok, Thanks man for the information....Oh and btw, I've got the sound figured out manually....Have not used YPAO yet. But am interested in seeing if my manual settings and its automatic setting are close.
post #960 of 2469
Are you using a SPL meter to manually set your speakers?
