Originally Posted by rwestley
I guess ghosting was the wrong term to use. I did not have enough time to adjust the the crosstalk to 0 so I guess some of the things I said may have been unfair. I just found that any movement on my part was the big problem with these units. I also found the unit very uncomfortable and I could not imagine having it on for a long period of time. I did mention this to the person doing the demonstration and she did say that one must not move around to enjoy the picture. I could even see problems with video games realizing that one often moves playing games.
I will try to be more open minded and test it again tomorrow or Saturday. I will also try to be very careful adjusting for the PD.
Hi, are you near sighted or/and having astigmatism? I found out if both our eyes can't focus perfectly, you will strain your eyes due to L/R image are not tally. I had a 0.5 astigmatism on my left eye and when I wear contact for 3D movie, I found out I had problem focusing on 114" projected screen from 12'. What I do to solve this problem is asking my optician to cut a lens to correct my astigmatism and use blue tack to stick to my 3D glasses.
Do a simple check as below:
1. Make sure you adjust the IPD. If L/R image is out of your IPD range, you may have a tough time to focus the image. At infinity, far object image should be your interpupil distance.
2. Do you wear glasses or have any eyesight problem? Try to out a simple test, close one eye and see if the video is sharp. Repeat with another eye and compare.
Also compare if both screen had the same brightness and images are consistence between L/R eye.
I believed there are group of people having trouble with 3D due to eye related problem. My wife can't watch 3D movie with too much pop out and will give her headache. She also can't watch movie that is shot with handycam style and the shacking will give her headache in less than 20mins. I think some people are immune to motion sickness. I'm train by Doom (ID games) to withstand motion sickness. Still remember the first time I play Doom, I had to lay on the bed for 2 hours with my head spinning around. It's the immersion that cause the headache due to our brain cannot intepret what we see and what we feel.
Unless you meant the 7 inch, 4x3 aspect ratio, 1024x768 LCD screens?
