AVS › AVS Forum › Audio › Receivers, Amps, and Processors › what mid-range receiver for HTIB speakers?
post #1 of 4
I have a 5 year old Onkyo 7.1 HTIB with 2 HDMI pass through. I am ready to replace the receiver because I need more HDMI input and no more pass through, but I want to keep the speakers. My most critical requirement is at least 4 HDMI in. I'd like the to play music on my hard drive or stream music from pandora, but that's not a requirement. I am not an audiophile as you can tell from the fact that I currently have a HTIB and plan to keep the speakers. I just checked the speakers are 130w 8ohms.
I don't need the lastest technology but it would be nice to get as much as I can for future expansion. I am looking at the Denon 2312, 3312 or Onkyo 709 or 809. Assuming I can get very similar price, which one is the best choice in my case? I mostly use the receiver to watch movies on DVD (regular, not BD) or hard drive via Briteview cinematube thru my optoma HD70 projector.
post #2 of 4
If you're going to spend that kind of money on a new receiver, you should also get better speakers!
You could get a lesser receiver like the Denon 2112 from Electronics Expo for $450 and then spend the remaining money on speakers.
These would be a significant improvement over your Onkyo speakers.
http://www.vanns.com/shop/servlet/it..._c=site_search
post #3 of 4
+1 on what afrogt said. IMO, speakers are the most important part of a home theatre.
post #4 of 4
afrogt, I can't find the Denon 2112 on EE for $450. It is not even there. Is that a refurb? I found it on amazon for $650. In that case, I should get something else. What about Onkyo TX-NR 609?
as for the speakers, can you recommend something smaller? I don't have the space to put the big ones (and sorry I don't even know if those are supposed to go to the front or back) plus it is a hazard for my household with a toddler.
