Originally Posted by
AndreasMergner
Maybe this will answer some questions.
8350: contrast "up to 50,000:1"
3010: contrast 40,000:1
8700ub: contrast "up to 200,000:1"
5010: 200,000:1
The 3010 is a step up from the 8350 because it has 3D....although no lens shift.
The 480hz panels are the same as in the Panny 7000. If you want to find out how the Epson may fare in 3D (ghosting), check out the Panny 7000 thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1363959
The Epsons should be brighter.
You cant go by the above contrast numbers as they will go up
THis is the Future Starting Line Up for Epson
8350.... staying
3010... New & not replacing8350 is an upgrade from the 8350 but Not Better than the 8700 spec wise
3010e.... Same But wireless
(3010 and 3010e are an up grade from the 8350)
8700 & 9700 both being replaced
5010..... Better than the 8700 and step up enclosure
5010e .... Same but wireless
PRo Cinema 6010... Better than the 9700
(rumors that there may be a 6010e)
Top Model
61000....... Top Model
Again 3010-6010.... due last week Oct first week November....
again if there is any new news will post on fb page
hope this helps
