AVS › AVS Forum › Audio › DIY Speakers and Subs › Lilmike's Cinema T-6
Lilmike's Cinema T-6 - Page 5
post #121 of 140
Originally Posted by bemmk View Post
Hi Mike,
I've read the thread of your tapped horn T-6. I've drawn your design on plywood, just to see if I can manage. I succeeded! I' m going to build the horn with a Jbl gto 1014. (bidding on internet, don't have them yet). You 've said earlier that: " JBL GTO1014 (make the cabinet 10-5/8" wide internally". You mean it should be narrower than the original width?
I did not draw your tarted version. Should I? What is the advantage?
I wil include a picture of my drawing. Thanks for your great work. I enjoyed working with it.
With kind regards
Koen van bemmel
The Netherlands
Full-width works OK too. Narrower just puts a little more load on the driver, the predicted response is a touch smoother is all.
"Tarted" is a harder build, and according to the model, it performs the same. I've only built normal ones.
There are plenty of other drivers if you don't get the GTO.
post #122 of 140
HI Mike,
Thanks. I'll stick to the normal ones
I can get two JBL gto 1014 for 95 Euro.
Just in case it wil be cancelled: in Holland we do not have every driver you mentioned earlier. What are the criteria for a good driver for the T-6?
SPL? frequenty range? Fz?
I will combine them with Klipsch heresy 3 (they can go loud).
Kind regards, Koen
post #123 of 140
Hi Mike,
the JBL drivers I mentioned earlier where not the JBL gto-1014 but JBL gt5-10. I calculated in hornresp with both drivers and the narrow width off the horn. The drivers gave practicaly the same results. Are these gt5-10 versions oke for the hornT6?
kind regards
koen van Bemmel
post #124 of 140
Mike,
I started reading your tutorial. forget about my questions above .I understand the compression ratio for speakers in a tapped horn. thanks . learning a lot.
kind regards koen
post #125 of 140
Hi Mike,
having fun with your design.
I cut the wood and started building. I attached a picture.
kind regards Koen
post #126 of 140
having fun!
post #127 of 140
up and running!
Mike thanks for your design
kind regards Koen
post #128 of 140
Nice looking build.
post #129 of 140
I've got a Fi Car Audio Q10 with dual 2ohm coils. Will it work in this enclosure? The sub is rated for 1500w RMS. Will it take that much power in this enclosure? Thanks. smile.gif
post #130 of 140
The Q 10 has too much motor to have a smooth response in this tapped horn.
post #131 of 140
:\ Bummer. I was hoping on doing something special with this sub. Thanks for the insight.
post #132 of 140
lilmike
When is the T-12 coming out? or is it?
post #133 of 140
Originally Posted by artyusmce View Post
lilmike
Well, I got distracted with the CVX-15s I have to play with, so I conjured up the MicroWrecker instead.
As far as the T-12?? Well, if one was to take the MicroWrecker fold, make it skinnier, and load it with a proper 12, you'd have one...
post #134 of 140
Thank you I will look it up
post #135 of 140
Nothing to look up yet - there is no official thread, just my build and one over at HTS.
post #136 of 140
Hi lilmike,
Do you have any external dimensions on the micro? I have been looking for something to fit under the stage.
I was going to use 4 Exodus Anarchy 6.5 kits I bought from Erich but now I’m thinking of a pair of something bigger.
The stage is 4' x 14' and 2' tall, joist spacing will be 18 or 23" so I'm looking to slide something between the joists.
Al
post #137 of 140
Originally Posted by allensbad View Post
Hi lilmike,
Al
Well, I thought things would have slowed down sufficiently for me to get a few things done....like building the second one and some further testing of the test mule...
Since the rest of my life has me considerably busier than I thought I'd be, neither one of those two items has seen any progress, so there's no official thread yet.
External dimensions are 47.5" tall, 24" wide, and 30.25" deep.
post #138 of 140
What are your thoughts about this woofer working in a T-6?
http://www.parts-express.com/pe/showdetl.cfm?partnumber=299-246
I bought one if these a couple of years ago cause I thought it looked good for the price. It would be awesome if it would work!
Thanks in advance!
post #139 of 140
Thanks in advance!
I grabbed a couple of those too... At least I learned something...
I measured them with and without the bucking magnets. Leave the magnets on, and use them in a small sealed box.
Nowhere near enough motor power for that driver to be useful in the T-6.
post #140 of 140
Thanks lilmike,
Looks like I'm out of luck..... again
Man I wish I had more space to work with.
Al
