AVS › AVS Forum › Video Components › Video Processors › iScan Duo Serial Control
post #1 of 3
This week I purchased an iScan due for use in my home theatre. I use Phillips Pronto as the control system for the theatre. I have the included RS232 cable connected between my Pronto Serial Extender and the iScan Duo. I spend the day programming the RS232 codes into the pronto and for some reason I cannot get the iScan Duo to do anything. I have verified the Baud Rate, Data Bits, Parity, and Stop bits match on both the pronto and the iScan Duo. I will post below what I have for a few commands. If you can verify I understand the commands properly, or if not help me out with how they should be that would be great. I have all of the information in the ASCII field in Pronto edit BTW.
Power on: STX3005A1NULL1NULLETX
Input HDMI 1: STX30054CNULL7NULLETX
Hopefully from that you can tell what I am doing wrong. Any help is greatly appreciated!
post #2 of 3
I would suggest perhaps sending barrygordon A PM here on AVS forum asking if he could
offer any assistance as he is an absolute Guru when it comes to this amongst other things, an expert with both Phillips Pronto & DVDO communication Protocols /RS232..
post #3 of 3
simplaylabs.com/support/DVDO_Documentation.aspx
  Back to Forum: Video Processors
