AVS › AVS Forum › Other Areas of Interest › Camcorders › Panasonic HDC-TM90
Panasonic HDC-TM90
post #1 of 4
I've recently bought this from bhphotovideo. But as it was from the US, it came with a 2 pin AC adapter.
Is it safe for me to buy this?
amazon.co.uk/Adaptor-Pin-into-Plug-Euro/dp/ B000MVDD2E <<<< space because of limitations
Or do i need to get those step up/down converters?
Like so,
amazon.co.uk/Step-Up-Voltage-Converter-110V/dp/ B000LB3HL2 <<<< space because of limitations
Sorry for being paranoid as i want to be extra careful of it. Its not a $10 thing i'm dealing here.
Another question, can i charge the TM90 by using usb.
Sorry for not putting the direct link as I'm new here and need 3 posts to post urls. Answers are greatly appreciated! thanks!
post #2 of 4
Like so,
Yes the power supply is auto ranging but its rated 110-240 volts, 50/60Hz so it may not function correctly if in Japan using 100 volts.
post #3 of 4
Ok thx. To my other question. can it be charged by the usb?
post #4 of 4
Correction! It does charge via USB when the camcorder is turned off! Found this in the manual and have not tried it yet.
  Back to Forum: Camcorders
