Originally Posted by
N3W813
My Nov12 set has significantly different default greyscale readings then my previous set. Therefore, the settings I posed for my previous set may not produce a desireable output for the Nov12 sets. I've calibrated my Nov12 ISF modes and it looks great. When I get a chance, I'll calibrate the Movie THX mode.
For now, use my previous settings but change the 10-point greyscale settings (all 10) to
R +5
G 0
B -12
Thanks, but I think I found out why
I went back over to my buddies house to hook up his Darbee
While there, I kept noticing that green leaf beside the backlight setting in the picture settings menu, and a green leaf next to the input label in the upper right corner.
I knew my set did not show this, and figured out his power management was ON.
Both my set and his set have the same firmware version (latest ver.)
I could not change it in the Power Options menu because it was grayed out.
I finally remembered that the little door on the bottom of the remote opens to reveal more buttons.
Inside this hidden section of the remote, there is a "Power Savings" button
The button will not allow changes in THX Movie
I switched to just "Movie" mode, and hit the "power savings" button under the hidden door.
Wala...Power Savings OFF..All the green leaves also gone. BTW...There are 3 different settings.. Choose OFF
I don't want the Elite to save trees
Next, a did a reset of all picture settings (he was using CNET settings)
Next I entered your settings (posted above)
Now its perfect, just like my set !!
Either 10 hours of use fixed it, or the Power Management was doing it
Either way, the green tint is gone, and all skin tones are perfect
So, you guys should make sure your power savings is switched OFF
I pulled up the full white screen and the 50% gray again with the TV in its final resting place.
Again, I am still saying this Elite is perfect IN THX MOVIE
No green, no pinks.
Very very slight gray bands off to the right side.
Here is a picture of my buddies
NOV2012 build of all white in THX Movie
TV purchased from Cleveland Plasma
Edited by obxdiver - 1/26/13 at 12:55pm
