AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp Elite PRO-70X5 and 60X5 Owners Thread
Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 424
post #12691 of 13284
Originally Posted by rhed View Post
Hey obx... For 2D anime.. You gotta watch Final Fantasy VII Advent Children Complete in blu ray. I thought watching this movie on my Kuro Elite was nice. Watch this movie again on the 70 this time. All I can say is WoW. The surrounds on this movie is fantastic too..
Thanks for the recommendation rhed
I will get that one next time I order movies.
I usually get 5-6 at one time and will add this to my list of "must have"
post #12692 of 13284
Originally Posted by R0ckets11 View Post
$3800 for a 70" Elite? Wow... this guy at BB was pretty adamant about $5000 being the final price.
They were the same way, like I said it took a good hour, I think it also depends on who you get to deal with, some Managers are easier, some not.
Also,this BB, is located in Paramus NJ, in the fashion center, if anybody is close, they still had two 60 Elites on the wall, no more 70's.
post #12693 of 13284
Yea let me know what you think of this anime.. Even now..After watching this movie again.. Makes me think our own anime like Pixar or Disney is far behind from Japan's anime..
post #12694 of 13284
Originally Posted by hutchinshouse View Post
Quick question. On my tv blue is too high. When running the 10 point grayscale I'm running out of control room. I have all 10 point blue settings set the their lowest setting, yet blue is still too high. Within the service menu on screen 7 (lines 1-7) there's something called R_A gain, B_A gain, R_A gain, and the three RGB offsets. Question I have, if I lower B_A gain will that correct my current high blue issue? If no, what service menu setting should I look for? Thx
Try THX mode and color temperature Low. You should NOT need to go into the service menu to get a good grayscale with THX and Low. Everyone, including myself, that has done a DYI calibration uses THX and Low. The hi/lo gains should provide you with plenty of headroom for adjustment.
post #12695 of 13284
FYI, I've seen this before, where even with the temp setting at 'Low' with all blue gains and biases set to the lowest points, the temperature still cannot get to 6504k. This will happen if the system board is replaced and the factory calibrated settings are not restored to the new board.
Did you happen to purchase a second hand unit? Or had the system board replaced because of IR issues?
post #12696 of 13284
I just bought a 70'' floor model for $4100 from my local best buy. It will be delivered Tuesday. It's an older build (serial #108811824) with a lot of hours, but I'm hoping any screen issues are minor compared to some of the Nov sets. I have 60 days to like or return it, although for the price I paid I really hope it's a keeper.
post #12697 of 13284
Actually my DIYs are in ISF and Low - I love using ControlCAL, so much easier and you get to save & restore settings readily. Also ISF has a lot better granularity, e.g. the gamma setting has 41 intervals instead of the 5 that THX has. But you do need the software to handle it.
post #12698 of 13284
Congrats. That serial # is close to mine, yours is also a Aug 2011 build, like mine. I have not found any issues so far, PQ is top notch.
post #12699 of 13284
I'm using THX. When selecting 10 point grayscale I don't have a color temp option. The only time I see a color temp option is when selecting 2 point grayscale. 10 point does not have a color temp option. Am I missing something?
post #12700 of 13284
so, im on my 4th set (had issues with the previous 3, including the worst offender which actually was a serial 108xxxx - go figure!) but am curious about one thing that is popping up.
i am trying to use my Disney Wow disc to do some rudimentary settings until i get a full calibration done.
when doing the advanced contrast test, on all the other sets the final setting would be somewhere around 25-30. on this particular set, i can go all the way to 39 before the Ideal Star disappears - should this raise any alarm bells that i have almost exhausted the useable adjustment range of 40? again, only reason it seems weird is none of the other other sets had to go that high before the Ideal Star disappeared.
this is in THX mode, Low temp setting if that matters.
thanks!
Edited by alebrady - 2/23/13 at 8:32pm
post #12701 of 13284
I had IR problems and had my board replaced. Blue is now off the chart. I am getting a new system board from Sharp.
post #12702 of 13284
I do most of my calibration in a Lumagen Radiance but to get white temp closer to 6500K I used the sets hi/lo adjustments. Then used the Radiance's 21 point gamma/grayscale not the set's 10 point. Perhaps, I misunderstood your question, but with the set in THX and color set to low the hi/lo changes got close to 6500 and blue was not an issue.
post #12703 of 13284
thanks!
What type of issues did you have? Did they send a tech out? Where did you buy it from?
post #12704 of 13284
Cool, that makes sense. I don't have a Lumagen. When trying a 10 point grayscale run I have all of blue's 10 points set to their lowest setting, yet I cannot get blue low enough. I have red on the high end, green near the low end, blue at the bottom, yet blue is too high when checking grayscale via Calman5. That is why I'm asking if I can bring down blue via the service menu. I found the RGB_A gains and RGB offsets within the service menu, just not sure if lowering B_A gain will bring down the TV's overall blue. Anyone know? Thx
post #12705 of 13284
De-select 10-point, then select the color temp mode, then re-select 10 point. Why it's that way, go figure rolleyes.gif .
post #12706 of 13284
I just checked, I have it set to color temp "low" already. :-(
post #12707 of 13284
Hi
this question is for people in this thread that have had their elite professionally calibrated: Is your gamma at -1 or 0?
I had mine done , however the calibrator made some final adjustments at the end of his work that didnt make it onto the setting document forwarded to me by email. The report says -1 but by TV was at 0 when i compared as a final check everything matched the report. He lives pretty far away so I wont be able to have him check which is correct in a while. I have Disney wow disc and tried to check myself , I read however on this forum the gamma test on this disc is not accurate.
thanks in advance
post #12708 of 13284
Originally Posted by slyboogy View Post
Hi
My 60" was calibrated by David Abrams from Avical and after calibration the gamma is set to zero.
post #12709 of 13284
Elite's Movie THX mode should calibrate close to gamma 2.2 if changes in the 10-point white balance are close to being linear.
There is actually no one 'correct' setting; you will need to find out what your calibrator set his gamma target to and the setting he used to reach that target.
post #12710 of 13284
usual green and red discoloration. one set also had a dead pixel. not tech was necessary, as the issues were plainly obvious. purchased through Magnolia.
anyone have any thoughts on my Contrast question?
thanks!
post #12711 of 13284
I'm having my 70 delivered Tuesday. I will need to test screen uniformity. It's an August 2011 build. I'm eligible for a free calibration by best buy. Will they run color slides or is that something I will need to do on my own?
post #12712 of 13284
The calibrator should have everything he/she required to do a calibration. You should not be expected to provide anything.
FWIW, if you want your set correctly calibrated, don't waste your time with a BB calibration. See if you can get a store credit for not doing the calibration. :P
Instead, get one from an experienced professional on these forums. smile.gif
post #12713 of 13284
New calibrated Movie THX settings for my Nov12 set. For this calibration, I used a 2.4 gamma target and a higher overall output, hence the higher backlight setting. These settings raise the black level just a tiny bit but provides a much better 'pop' to the image. For a dimly to moderately lit room. The higher APL may be too bright for a fully darkened room but you are welcome to try. smile.gif
*This method was taken from a discussion thread by PlasmaZ580(sp?) and ChadB in the Calibration forum.
post #12714 of 13284
Hi all,
I've been lurking in this forum since May 2012 when I first got seriously interested in the Elite. Countless hours was spent reading up here and elsewhere and badgering the guys at my local BB. After a 1st attempt to negotiate the tv to a palatable price I had to walk away due to not being as affordable as I wanted, and not having my ducks in order. The next few paragraphs is my story, you can skip that if you like but please see my questions near the end.
Several months pass and as my situation improved I began looking at TVs again and tuned to the VT50 and HX950. My brother has a VT30 and I figured if the PQ on that was acceptable then the VT50 and later ZT60 has to be even better. Coming from a Sony XBR5 and a 36XBR400 before that, I always had a soft spot for Sony. I walked into the Sony style store and look around, I wasn't impressed. SOE was distracting, and even with processors were turned off, it seemed everything was blurred. Egg shaped golf balls, people moving looked as if they has Sonic the Hedgehog shadow trails all over. I generally wasn't impressed. So I was set and intent on getting the VT50 since price reductions made it a great buy or ZT60 if I could have waited longer.
I walk in to the local BB and bam there it is sitting where it always is and i get drawn to it, the 70"elite. It reminded me of how glorious the gold spinning dragon and night city scapes were. I turned to look at the VT50 for a second, then recalled my family room. Too many windows and lots of potential for the plasma to get washed out. Next I noticed the price tag on the elite, they dropped it beyond their usual $7000 sale price. I ask the guy what the deal is an he informs me the elite has been discontinued and that they are unloading the floor model. My interest perk up even more, so I do a quick visual check. No physical nicks or dings to the case, and 99.9% of the finger smudges on it wiped off easily.
I walk out of there and come to this forum to catch up on the news: nov2012 issues, IR loss, cyan issues, pulsing, etc. I almost get cold feet. I go back the next day and reexamine the set, no green or pink blotches, I look at the serial #, 206xxxxxx! So it's only 6-8 months old, not the 1.5 years I was figuring to estimate the LED light wear. I softly negotiate the sales guy. He knew me from my first visits back in May, and after I reminded him, he remembered the price point I was gunning for back then. He disappears comes back and say, we can do it, but you will have to get the PP. I balk, saying the plan is too much $. Why couldn't you just sell it to me for my price, and let me decide later on the plan. He goes away again and comes back. Done! They bubble wrap the set and I bring it home.
Looking back, i know i probably over paid for a floor model, seeing that some people paid the same for a brand new boxed set. I didnt feel like negotiating hard, and wasnt sure how serious i was at the time. I feel better knowing i dont need to play panel lotto, and even with the usage this thing had gotten, it only serves to advance any engineered failures to hopefully occur within my warraties or protection plans. An added bonus was they found a brand new remote under the media stand, still in the elite instruction box. They gave that to me as well as the grimey remote that everyone has been beating up and two boxed 3D glasses.
I get it home clean it up and fire the baby up.
My jaw is lost on the floor under the sofa somewhere. It looks better in home than in store. I play with the menus a bit, reset a few items get it out of the retail torch mode and punch in newbies settings; glorious. I never liked Thx calibrated screens before due to the muted, washed out look, but with this set up the colors have enough pop for me to keep it as the full time every content type setting.
Despite a few flaws being the floor model: scuffed up stand, no worries, I'm going to wall mount it. 1 dead yellow sub pixel, I can't see it from the sofa and its only visible from 12 inches and on all white scenes. Small 3mm x 3mm scuff on the anti reflective coating that does not come off, again cannot be detected from sofa. I love the set, and after canvassing the area BBs, the other 70" elites were in worse condition than this. one had 3 dead pixels, scuffed up stand and the other had nicks and dents all over the bezel.
So I am keeping the elite. I am training myself to stop looking for issues and enjoying my elite. Some one could make a ton of cash starting up a 12 step program of sorts to curb OCD toward gadgets. Thanks to all the great people and your posts in here. Lots of good info and knowledge floating around. If a picture is worth a thousand words, there aren't enough to describe the one on an elite.
So to bug you all a little more, my questions,
1) I registered my set on the elitelcdtv site. I recall reading here that some were offered an extended warranty from sharp via email. How long did it take for that email to come in? Do you think given their current state, they may not be offering that anymore? Is the service, if they still have it, any better than BB's $700 5 year plan or the $99 3 year extension plan from Costco?
2) when I first turn on the set, the screen lights up with a black screen where it seems the back lights are on full blast and I can see clouding/light bleed all over. Then when it picks up my receivers signal, it tones down to the normal glorious black levels that we know. Is that normal? Should I be concerned with the clouding during that instant as something that could be a problem later?
3) how do I get into the service menu? I don't care to change anything there, but I read there is a way to view the number of running hours on the set in there. It seems accessing that menu is somewhat taboo both here and throughout the Internet, as no google search I have done revealed any answers. Why is that?
4) is there a master reset for the tv? I've gone into the menus and hit the reset option where ever I've seen it, but there are several resets to be done, and i dont know if i've hit all of them. is there an all encompassing reset to get everything to factory defaults and rid the set of any polluted settings done by BB or customers that have toyed with it in store?
Thanks again to all that contribute here.
-Patrick
post #12715 of 13284
post #12716 of 13284
Bluez3,
I don't know about the other questions, but I can tell you my set also has very light black for the first 2-3 seconds before it goes near jet black. If you see no issues with normal content I wouldn't be concerned.
post #12717 of 13284
Bluez3, I too have some clouding, along with some dse issues, but if your set is like mine, then you should be fine. I rarely notice the dse issues, unless I'm looking for them, and the clouding I never notice (with local dimming on) even when looking.
post #12718 of 13284
Hey Newbie - Thanks again for posting all of your settings.
I'm a little confused with this newest set though as the 10 pt setting has been switched off compared to your earlier calibration. From your explanation it's clear you were targetting black levels this time around, but I'm wondering if/how colour accuracy has been impacted? Are both results equally close to reference? I'm sure there's as much art as there is science to calibration, and I could just try the new settings and see if I like them better, but I would prefer to stick with the "more accurate" settings (notwithstanding the Elite's issues with cyan). I'd get a professional calibration, but I've described here before my inability to find a calibrator willing to do the ISF modes on the TV.
Cheers,
JD
post #12719 of 13284
Originally Posted by Sick Mother View Post
Bluez3,
Same here, my set does that when I first turn it on. But no problems once the content is actually showing. I wouldn't worry about it.
post #12720 of 13284
For the new settings, I decided to use 2-point grayscale because it gets me very close to the same results I would get when using 10-point. Saves me some time during calibration.
Yes, these setting are as close to reference as I can get them on MY Nov 12 set. There is no way I can say which set of settings will look "more accurate" on your set. Just try them out and see which set you like better. If you decide you want "accurate" settings for your set, you will need to get your set professional calibrated. smile.gif
There are plenty of calibrators that can calibrate the Elite's ISF modes. wink.gif Did you trying searching or posting in the forum thread below??
http://www.avsforum.com/t/586330/isf-calibrators-where-are-you-located-please-post-here
