AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp Elite PRO-70X5 and 60X5 Owners Thread
Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 47
post #1381 of 13284
Regarding color accuracy:
I've actually found cyan and colors around cyan to be more problematic than yellow. Yellow is easy to control in the CMS section, but getting accurate cyan as well as other colors in that neighborhood are very difficult IMO in the THX mode. In fact it's one of the reasons I prefer the non-THX movie mode for color accuracy. In that mode it seems easier to get accurate colors. Of course all of these observations are on a non-ISF'd panel.
I'm not one of those that believes the THX mode is so 'spot on', I just don't see it. The colors are gorgeous, don't get me wrong, but if you really begin examining color accuracy critically, you'll see there's room for improvement. I'll be so bold as to say the 929 has better color accuracy out of the box and with a few simple touch ups than the Elite. And yes, I prefer the Elie over the Sony.
I've mentioned this before, but simply look at the color of the glass blocks behind the couches on the Today show. In actuality they're a distinct purplish hue that you'd never know while in THX mode, which renders them blue. The non-THX movie mode renders it more accurately, but still not spot-on. One look at my ISF'd Kuro shows how off the Elite is in this area of the color spectrum.
I'm very curious what the potential of the ISF mode is once unlocked. I'm hoping for better accuracy than the THX mode seems capable of.
post #1382 of 13284
"I'm very curious what the potential of the ISF mode is once unlocked."
i'll let everybody know in a couple of weeks..
post #1383 of 13284
The 2011 Quattrons color space calibrates very accurately including the yellow. Each primary and secondary color have their own hue, saturation and luminance adjustments. Yellow can be calibrated to Rec. 709 specs on the 2011 Quattrons. There is no magic formula or special procedures to calibrate the color space on these sets compared to any other display.
post #1384 of 13284
Or I can let you know right now...it's amazing, color accuracy is spot-on, greyscale as well...been watching a good amount of black and white Hitchcock films and such, and knowing these as I do from my calibrated Qualia 006 when it was spot on, these films are exactly as they should be. And as far as color, of course things like the colors on the Leno show, Lord Of The Rings blurays, etc. tell me it's spot on there too...as does the color scale test from the D2V's video processor. I believe from discussing with Ed Johnson that he got the colors and grey scale absolutely perfect on ISF Night and Day for me.
In short, I think both you and Ken will be quite happy all the way around once calibrated.
Cheers,
Brian
post #1385 of 13284
Originally Posted by rogo View Post
There is no adjustment for the yellow. Yellow is normally made by red + green. In the Sharp, it's also made by shining the backlight through the yellow-filtered pixels. The settings of the R and G determine whether or not light is shined through the yellow sub-pixels (the blue might as well, in some strange way, but I'm not suer how or why that would happen; I just don't want to rule it out).
When you set the R, G and B in the panel, the TV is doing a lot of internal magic to determine how much to twist the LC material in the corresponding sub-pixels which will determine how much light gets through. It doesn't actually manipulate the pixels material. So if you make a change to R and G in a Quattron panel. the Sharp might allow more or less light to make it out through the yellow sub-pixels, but it's no trickier than that.
Thank you. I thought that was what another calibrating genius had told me but I wasn't sure.
post #1386 of 13284
Cheers,
Brian
That's what I'm expecting, thanks. Brian, just out of curiosity, if you can record the Today show and take a look at those glass blocks I was talking about, I'd like to get your reaction to the color you see in them.
I have other examples such as the FIOS TV guide, but obviously you have to have FIOS. Some of the guide's colors shows major differences in THX mode as opposed to non-THX movie mode. I only use that as an example because it's easy to recall and it's static. Looking at that same guide on my ISF'd Kuro is quite different.
post #1387 of 13284
Sorry for the complete non sequitur, but what suggestions would you guys have for power surge protection for this tv?
post #1388 of 13284
Originally Posted by tangcoma View Post
How many depth u set ? The max is +16 , and I saw lot of Crosstalk there in a store ! Can u see it too ?
I didn't even know that I could adjust the 3D depth. I'll have to check the manual...
What do you mean by "crosstalk"?
post #1389 of 13284
Funny you should ask that - we just had a power outage last night, and my APC J15 Power Conditioner wasn't able to keep the TV powered on. I can't understand why, because every other peripheral remained on, and the TV I just replaced (Sony KDS-R70XBR2) remained on when the power went off.
The unit is supposed to deliver power to all equipment as if the power is still on for at least 10-15 minutes (if not longer). In the past I never had a problem, but either the J15 is getting old and needs to be replaced, or there's something about the 70" Sharp Elite that requires more than just the J15's battery power.
The TV still works fine now that the power is back on, so at least the J15 protected it from surges and fluctuations, but I'm probably going to have to find a new or better power conditioner if my J15 can't handle the Sharp Elite's power requirements during an outage. Perhaps I need to upgrade to the APC S15, but that's a lot of money!
post #1390 of 13284
So the Crosstalk is meaning the right eye image is leak to the left eye ! The left eye does the same ! So u will see a double image there !
post #1391 of 13284
OR the S20.
post #1392 of 13284
People get confused by how LCDs work -- not saying you did necessarily. Quite literally there is one color of light operating behind the panel. And there are three (or four in Sharp's case), color filters that change the color of said light before it reaches our eyes. The only way the TV can modulate color is to block more or less of the light at a given sub pixel ("give me a little more red", "give me a little less blue"). Everything that happens to get you a shade that isn't one of the colors of the filters is done through "magic" -- or a series of calculations.
Setting "hue" is actually fairly easy, but even saturation and value (sometimes called "brightness") is done through the same mechanism. "How much light do I allow or block?"
There's a good discussion of color here: http://www.ncsu.edu/scivis/lessons/c...r_models2.html
Just keep in mind, the only tool the LCD has is to block more or less of those primary R G and B (and yellow in the Sharp). In theory, the Sharp method would allow more flexibility. In reality, as many have noted, non-4-color sets have managed just fine and Sharp has had issue translating its control / algorithms into the best results in the past.
post #1393 of 13284
De
Thank you again, and yes I have no idea how lcd's work. Judging by how things are going with plasma I think I might need to learn.
post #1394 of 13284
I've asked before, but, I would love to see comparison shots of THX mode and ISF mode.
post #1395 of 13284
Mine will most likely be calibrated by D-Nice on 10/14
post #1396 of 13284
Love to hear your feedback on D-Nice calibration.Last summer he did my 8500 and it was like night and day to what I had before he came.Cant justify an Elite Sharp purchase since my 8500 is so amazing.
post #1397 of 13284
Yeah, I'll post impressions but he did my pro141FD so I know I'll be happy. Forget about screenshots from me though as I'm no photographer Unless you want me to turn out the lights and take a picture that's about the extent of my capabilities lol
post #1398 of 13284
I finally got to see one of these in person today at a Magonlia in Best Buy. First off, happy to note that what I was looking appeared to be very close to accurate as far as colors, so I asked the salesman what mode it was on, and he said THX (he said there were 2 thx modes, one was Movie, and there was another.. not sure which it was on).
He put it in Elite color mode, and I didn't like it.. everything became more cartoonish (it was already playing an oversaturated transformers movie, so going to Elite mode made it even more exaggerated)
Off-angle viewing was a lot better than I expected... You could see blacks turn to a bluish color, but not really bad at all IMO. Glare wasn't as bad as I thought it would be either... There was a 70" sharp non-elite which was probably in torch mode (colors looked horrible, so it's my assumption).... but the blacks really bad on off angles...
post #1399 of 13284
Could some of the Owners try Hitting the Light button on their remotes. When mine Lights up the #9 is brightest of all digits and some function buttons are hard to see cause some are real Dim in comparison to others. I may have to get them to send me another remote cause when it's a dark enviorment I can't see some of the Buttons. I think for a $8000.00 retail Display that they say has a backlight Remote, it should be a good one.
Check it Out.
Glen
post #1400 of 13284
He's wrong, there's only one THX mode.
post #1401 of 13284
Check it Out.
Glen
Mine is the same way, but I never use the remotes that come with equipment I buy, so I don't pay much attention to things like this.
post #1402 of 13284
Check it Out.
Glen
On mine the on/off button and the 9 are by far the brightest. All the others are the same brightness = dim.
post #1403 of 13284
Ken: Regarding your comments above about the glass bricks on the Today Show interview area, the ones above the blue appear to be light magenta in color with low saturation than anything else to my eye. This was in THX which I have calibrated using a Chroma 5 and Chromapure. The flesh tone results are the best I can remember seeing on any TV.
post #1404 of 13284
Can some owners take some pics with daylight? Lights on in the room? Try to capture worst case scenario. I have windows behind me when I'm watching so I'm trying to get a feel for if the TV is even usable with daylight or lights on in the room. We also have recessed lights in the ceiling.
thanks!
post #1405 of 13284
Here's what it should look like (and does on my Kuro when actually watching the show). You'll see it's definitely not as you described nor as depicted on my Elite.
Scroll down about 2/3s of the way until you see on the left hand side "Moneyball author bounces back...". If you look at the glass block in that picture, you'll see what it's supposed to look like. I can't get the Elite to look like that no matter what I do...closer in non-THX movie mode, but still not like that.
http://today.msnbc.msn.com/
post #1406 of 13284
Anyone have luck using a Harmony One remote with the Elite?
post #1407 of 13284
It's no longer available although I did see it on my Ipad earlier. Looked terrible on Ipad. Which bricks are you talking about? The bottom and far larger area appears light to medium blue and undersaturated due to being glass. The upper area is as I describe above.
post #1408 of 13284
Just use the KRP 500m as the TV and you will be fine for now.
post #1409 of 13284
Well, sort of. That will not provide discrete on/off Power codes that will work. It will only provide a Power "toggle" that simply does the opposite of the set's current state - just like the included Elite remote. Unless someone can confirm that they have discrete "Power Off" and "Power On" working via IR remotes of any kind, we are still waiting for proper codes there, and I for one haven't given up trying.
-Brian
post #1410 of 13284
Take a look at this link and look at the shot of Cheney on the right. The purple glass blocks are there and look as they do on my ISF'd Pioneer Kuro. Quite 'purple' and not the color I'm able to produce on my Elite. The Elite is much closer to blue.
http://www.nydailynews.com/topics/The+Today+Show
