Originally Posted by winston9332
While in Chicago on holiday this weekend, I stumbled into a Magnolia (vernon hills - vermin hills for libertyvillians) that had a 70" elite on display. Firstly, the black levels were impressive, but shadow detail was not. There was clear aliasing in movement, although the frame interpolation was very good. Mosquito noise reduction was excellent. I have always been drawn to plasma, but was impressed by this set, which was uncallibrated. That said, the motion/fluidity was noticeably inferior[/b] to the VT30 across the room.
Originally Posted by RadTech51
I owned the VT30 and I can tell you first hand that the motion was marginal better better at most. Certainly not by much as much your claiming or it would be an issue, which it is not. Motion on the ELITE is simply the best I've seen on any LCD TV. What settings did you have the ELITE on when you were checking it out? Under what lighting conditions? If your seeing issues with the shadow detail then you probably were not in THX picture mode, were you? Additionally I'd be curious to know how much time you spent with the set to be making such claims?
The best part of this exchange was that Winston merely said "noticeably" inferior, a point that was actually conceded in the first sentence of the ensuing reply. Any degree to which he found it noticeable was not even specified by Winston in that post, but only imagined as a straw man to rant against.
I have to say I'm enjoying the dichotomy of reaction to the feedback here. Positive reports are taken at face value & praised, while anyone of the opinion that the Elite does not quite measure up comparatively- in any respect, to any degree- is immediately faced with questions about how much time they actually spent with it; whether it was properly setup & under what conditions; & some were even accused of lying about their experience with &/or ownership of the model! Does make for a good read though.
