AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp Elite PRO-70X5 and 60X5 Owners Thread
Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 104
post #3091 of 13287
Originally Posted by pinktri View Post
changing the topic for a second can anyone help me out? When using the apps such as youtube or netflix, how do you guys deal with audio when using an AVR. Do you use the optical audio out to an input on the AVR and switch the input on the AVR every time you use an app? Is there a better method? Also if I use the mini jack out on the elite to an analog cable on my AVR will it be 2.1 or will I be able to use my center channel 3.1?
I use the digital optical out and simply switch my AVR to "TV" when watching app content. The only thing that sucks is if you are watching 4:3 content via an app. You can't scale it to fit the screen.
post #3092 of 13287
Originally Posted by AZREOSpecialist View Post
And some of us with Dish DVRs have no such option. We must select a default resolution, the highest of which is 1080i.
Yeah, that sucks, trade in that crap-tastic DVR for one that has a 'Native' mode. Perhaps you've already tried that and they don't offer one or something.
-Brian
post #3093 of 13287
-Brian
I don't believe any of Dish's DVRs, including the Sling-loaded ones, offer such a picture mode setting. Apparently the setting was available during a software beta earlier this year or last, but was removed from the final software due to possible consumer confusion over what the setting does. My understanding is that companies like Dish calculate how many support calls a new feature will generate, and make a cost-vs-benefit analysis on whether to include a specific feature.
But I've noticed this "pulsing" via three distinctly separate components and two different data paths. I can see the issue on my Dish DVR as well as my PS3, both of which are routed via my Denon AVR (pass-thru, video processing off). PS3 video mode is set to "Automatic", Dish DVR is set to 1080i. I have also seen the issue while watching Netflix content using the native app (direct data path, no AVR, no option for RGB vs YCbCr).
post #3094 of 13287
I agree with what you're saying but how come the feed on my 600m looks soooo good for the exact same game? Even my old first gen 720p panny in my bedroom looks much better. Can't wait for weekend so I can test more football games. Maybe it has something to do with the fluorescent lights because both games were played at night? I don't know.
So are you saying that the Elite looks great with all your other channels, compares favorably on those channels & sources with your 600, but falls short on those two games you watched?
If that's the case, I have no idea why that would be. I don't know why that one type of broadcast would be like that. If the greens were so weak on the games, I'd think that same issue would reflect too in other broadcasts with green. Anything with green grass or other things 'green' such as you'd see in movies, sitcoms, dramas...anything with greens, would manifest itself there too.
But it seems you're only seeing this with those games.
post #3095 of 13287
all you have to do to get rid of that pulsing is to sell it to some avs member.lol
post #3096 of 13287
Here's a really poor action shot from last night but you can see in the middle of the screen it's really white or high contrast looking. When viewed from my other tv there is no hint of this and the field, uniforms and helmets look deep.
Hard to tell from that pix, but the green looks OK and not unlike what I've seen on some broadcasts on my Kuro or Elite. Again, without knowing how it should look, it's almost impossible to tell whether it's right or wrong.
But if you feel you have a contrast issue, have you tried lowering the contrast? Have you turned off all contrast enhancements? These usually do no good if you're looking for accuracy.
post #3097 of 13287
Originally Posted by BFJ 96 View Post
LED are meant to be brighter, hence why it would look different.
And that's a good point even if it seems a bit off-base to some. He's comparing the Elite's picture to two plasmas that are not capable of achieving anywhere near the brightness/contrast of the Elite.
A possibly interesting test would be to lower the brightness & contrast to levels that match his two plasmas and then see how the saturation looks. It's perfectly natural for color to appear more saturated as you lower brightness and/or contrast. But first he needs to ensure that all 'enhancements' are turned off.
post #3098 of 13287
Unless I'm misunderstanding this, if your connected via HDMI from your AVR to your Elite, why would you need to change audio? Ah wait, you don't have ARC on your receiver correct?
It didn't occur to me that the audio return channel enables audio from the TV to go straight to the AVR. Hmm, I guess you'll need to use that optical cable.
post #3099 of 13287
Yes this is the case. Actually I use the HDMI for video only straight from the STB to my elite and optical from my STB straight to my AVR. I do this to bypass my AVR' video processing because my AVR does not have a bypass option. Same with my PS3 setup. No additional optical ports on my AVR so I'm forced to use the mini-jack port to get sound from the elite to my AVR.
post #3100 of 13287
I know it sounds crazy but it's what my eyes are telling me. 2 football games played at night is a small sample size so i'll report back on saturday and sunday.
The only other thing I can think of is the STB but they are the same model for both tv's. Believe me I wish I did not have to write these things but like I said outside of football (maybe its just night games) and standard def viewing (my kid's shows) the Elite clearly is better and I'm very please with the picture. I hope this does not deter anyone from buying the elite.
I've tried to play with the contrast and brightness but it does not help the washed out look. It's as if I'm watching the elite from a slight angle and the colors have shifted or look washed.
post #3101 of 13287
pinktri
Swap out the STBs.
post #3102 of 13287
Seems like the same color issue on Sharp Xs1 fixable with CMS adjustment. Picked up a XS1 52" for 1K, very nice set but the Bannner on the Direct TV was a shade of green instead of blue. I know it is blue on my Sony and LG sets. The following screen shot shows the CMS adjustment that fixed it when when I set the cyan to plus 15. Does the Elite have this adjustment?
This XS1 while I am not comparing it to the Elite has much better contrast and blacks then my LV9500 Nano set.
post #3103 of 13287
pinktri...
i'm glad that things have for the most part worked out in your favor. i agree w/ ken about that football image. it just doesn't look that bad to my eyes, but i don't have my 8500 to compare like you have your 600m. since your nearby ABT i sent back my 70" maybe you can score a good deal on a open box discount. have you watched any sitcoms on the elite yet? this is where the pulsing was the most troubling for me.
post #3104 of 13287
thanks airgas, not too much sitcom viewing yet but I will and update when I get a chance. I live right next to Abt and have a very good friend who works there. I'll definitely be on the look out. Sad to see if you're done with the elites, what next?
post #3105 of 13287
Just so you know, I had raised my green saturation in the CMS section to +10 if I recall correctly. You might try something like that.
post #3106 of 13287
He's getting a 19" Vizio.
post #3107 of 13287
I was thinking more along the lines of that stunning 19" coby that bb has.
post #3108 of 13287
Sweeet display Airgas!!!
post #3109 of 13287
Brian, I thought he had already used 'native' output on the STB, but maybe that was another poster. The only problem using native output IMO, is the constant resynching the display must go through as you cycle from a 1080i channel to a 720p channel and back again. Historically I've found this flashing and delay annoying enough, that I've set my boxes to a fixed 1080i output and I've been happy. I'm not sure if it's the fact that the Motorola STB have decent enough scaling, but the slight difference in PQ between letting my Kuro/Elite do the conversion on 720p>1080p vs the STB, is not worth the annoyance for me of the delay & flashing. I know others feel differently, so it's just how it hits you.
For color space, I agree, I've always used YCbCr on all my non-PC components.
Native mode is borderline unusable on DirecTV DVRs as well. It's so ridiculously slow that you basically can't channel surf anymore if it's on. I do what you do and the results are sufficient.
post #3110 of 13287
Where can I buy additional 3D glasses for the Elite?
post #3111 of 13287
Originally Posted by Glenee View Post
There are alot of Fine Displays out there in your price range and I doubt you will ever see any difference.
What does that mean in my price range? I just said for the price not for my price. It Maybe better than the Kuro in terms of fearures, but it's definitely not a Kuro "KILLER". Like i said maybe it was the lighting or the Geek Squads calibration that bring out the best in display.
Has Chad B, D-Nice, or one of the pro calibrators gotten there hands on one of these and done a review?
post #3112 of 13287
Kevin Miller has:
http://www.**************.com/showth...klit-LCD-Panel
edit: wow really? I can't link to another forum?
post #3113 of 13287
"Killer" is in the eyes of the beholder isn't it? I have both the Kuro Pro 151 and the Elite and I prefer the Elite's picture.
Kevin Miller has done a review on it as have a couple of other websites like this one. Enjoy reading it.
http://www.hereshow.ca//Hands-onRevi...-inchHDTV.html
post #3114 of 13287
Kevin Miller has:
linking to another forum site is forbidden..
post #3115 of 13287
Thanks Ken!
What about links on calibration. I saw a episode on Tekzilla, where they compared a few models, including the new Elite, VT30, D8000 and few others. I believe overall they said the D8000 was the winner. A couple of the calibrators said that the display had color issue, which are mentioned in the thread.
But like you said, PQ is in the eye's of the ones doing the viewing. Which is all I care about. Not interested in 3D or the whole smartTV thing. In your opinion on a scale of 1-10 how much better is the overall PQ compared to a 151.... and was that quality worth upgrading to the Sharp? PQ only!
post #3116 of 13287
thanks! must have missed that under the rules....
post #3117 of 13287
Wow, such a rule seems extremely insecure.
post #3118 of 13287
^^^ rotfl
post #3119 of 13287
Any Elite dealer should sell the glasses as well. I know Magnolia carries them for sure.
post #3120 of 13287
Nahh, not unusable at all. Maybe it has something to do with my Anthem D2V in between. But my channel changing from DirecTV DVR's in Native mode, and Tivo Series3 for cable in native mode, are very fast.
