Originally Posted by Ken Ross
Please don't interpret my switch to feeling any differently about the 929 than what I've posted since I owned it. It is still a fabulous set with an incredible image. I was really feeling I wanted the extra size and I also wanted to see if the DSE could be minimized with the Elite. As I posted in the Sony thread, DSE was my biggest issue with the display.
But in no way would I hesitate recommending the 929 to a friend.
Now, is the Elite worth 2X the price of a 929? I think if you shop around you'll find the differential is not quite that bad. As to whether it's worth it to you, that depends on how much you'd appreciate the extra size with the extra edge in PQ in certain areas. As I said in my mini-review, nobody can say if the value is there other than the prospective purchaser. For some the answer will be an unequivocal 'no' and for others a resounding 'yes'.
Either way there really is no mistake in choosing either.
I'm going to hold onto the 929 for awhile and see how the prices shake out on the Elite sets. Glad you have a set you really like. Luckily DSE is very light on my 929 or I'd be in your boat. DSE is why my 111FD went back.
The price on the Elite even after some shopping is holding me back. If that 60" gets to $4k or less I'm in.
