AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp Elite PRO-70X5 and 60X5 Owners Thread
Official Sharp Elite PRO-70X5 and 60X5 Owners Thread - Page 255
post #7621 of 13287
Originally Posted by airgas1998 View Post
come on Ken, you have to be a little skeptical at this point don't you?
Being skeptical is one thing, flat out saying a fix isn't coming is another, and completely baseless.
post #7622 of 13287
Originally Posted by genewildershair View Post
being skeptical is one thing, flat out saying a fix isn't coming is another, and completely baseless.
+1
post #7623 of 13287
Well skepticism is fair, but that's different than an official sounding "there will be no fix". The latter sounds like the poster has some inside track.
post #7624 of 13287
Originally Posted by Ken Ross View Post
The only problem with the theory that all sets have the pulsing in all modes is the fact that there are people like me who see pulsing clearly in one mode, but not in others. I have it in non-THX movie mode but not in THX or ISF modes. So it's clearly not a question of not recognizing the pulsing, we see it in one mode and not the other.
Ken, I don't think it has anything to do with the mode. I think the reason why it goes away for you when you change to anything except movie is that the picture gets brighter. If I up'd the brightness the flickering went down on my set. Much like raising the ambient light of the room reduced the problem. Of course it is just a theory, but we do have a lot of confirmed sets with the problem in THX mode, so I really don't think this is limited to a movie mode-only problem. It very well may be source material based too... I'd be curious to see if you have the problem with Darker Than Black in THX mode with no ambient light.
AnotherDude, there may be slight differences in the TVs that are causing the problem. As for settings, I know Ken and I were using the same settings for a while (CNET). I tried all of the recommended settings given in this forum but the flickering remained (to different magnitudes) in each one.
post #7625 of 13287
I think we're both saying the same thing - the mode changes how the set responds to variations in brightness. And as I like really deep blacks and dark shadows, I'm kind of glad I don't get the flashing / pulsing more than I actually do - I calibrate with the backlight at 25 ISF (0-100 range, 50 default), which I think works out to something like -15 in THX (-30 to +30 IIRC).
I often use the CNet THX settings for comparison to my calibration. When you say Darker Than Black is that a movie or reference to the brightness? I set mine so that the 2% level is just visible and darker than black looks like black.
post #7626 of 13287
Actually for my current settings Jeff, the picture doesn't get any brighter in ISF Night mode, yet the flickering is gone.
post #7627 of 13287
Even with flaws...I just watched frozen planet...amazing pq
post #7628 of 13287
Picking up my 60" Elite on Friday and would like to contribute my perception of the issues with my set. Is there a way I can replicate settings and source material to say yes or no on the pulsing?
post #7629 of 13287
my inside sources tell me no cyan fix...better?
post #7630 of 13287
and your inside sources on the ld flaw?
post #7631 of 13287
Fix or No Fix. My inside sources tell me I'm Keeping Mine.
post #7632 of 13287
Originally Posted by glenee View Post
fix or no fix. My inside sources tell me i'm keeping mine.
+1
post #7633 of 13287
so Kevin Miller just posted a response over at HDJ...hopefully Kevin can answer my question here at AVS or someone will re-post my question to him over there
Kevin:
can you talk about the overall 'eyeball test' versus the accuracy of the colors itself on the Elite...seems like the Elite owners and advocates continually go on about how the Elite 'looks' great to them regardless of any measurement errors and how that is far more important then data points...I remember 2 years back at the Shootout you guys tested the LG LX9500 and the measurements looked spot on but it failed the eyeball test...so the Elite does the opposite and am wondering how much weight you place on this
post #7634 of 13287
Ken, the 151 is for sale!!!!!!! you must be in for the long haul
post #7635 of 13287
It's not that simple because the pulsing is material dependent. Whatever material you're using to look for pulsing probably just doesn't show it in THX or ISF modes. Before I returned the TV, I saw plenty of scenes that had severe pulsing in 'Elite Pure' but none in THX. Eventually I found a good test scene which showed the problem in all modes.
I can re-upload the test files again if people really want them. But if you're happy with the set, I suggest just leaving it alone - it's one of those issues that you can't unsee and it may ruin your enjoyment of the TV.
post #7636 of 13287
Hi everyone, I have been following this thread for awhile and am continuing to sit on the fence with this display. My question would be to the owners mainly the 60 inch owners( that's what I'm looking at) knowing what you know now about the Elite would you still purchase it? I'm looking to upgrade my pdp5010 and want something a little larger any insight would be appreciated thank you.
post #7637 of 13287
I've got the 60 and yes, I would without question do it again in a second. There isn't a display out there with a better picture IMO.
post #7638 of 13287
It's very material dependent, no doubt about it. But It's not just my test material that doesn't show the pulsing in THX or ISF modes, it's any material from any source. In those modes I have not seen one instance of what I see in non-THX mode. I certainly know what it looks like, I'm sensitive to it (my wife isn't), but it's just not there in the modes I mentioned for any material, from any source.
If for some reason the test material you had showed it on my display, I certainly wouldn't worry about it in my setup since the material I watch has never shown it.
post #7639 of 13287
Yes, we are saying the same thing.
Darker Than Black (vol 2) is a show reference, and the material that I used to illustrate the problem to the Sharp Engineering that came to my house. It was far and away the worst flickering material I've seen. If you are looking for the problem that would be my recommendation for source material (though I admittedly did not try Wizziwig's).
I concur with Wizziwig you probably don't want to look for this problem. I'm sure for the first week I saw the flickering and just assumed it was part of the source material. After watching a couple of scenes with prolonged periods of flicker it bothered me enough to look into it. Once that switch flips from assuming its the source to realizing its the TV you see the problem more and more. Even worse, you start noticing flickering is source material that you never saw before (Robot Chicken is an example).
While you are probably best off following Wizziwig's advice, there is a part of me that selfishly would like more people gathering data on this in hopes of helping Sharp isolate and fix the issue.
post #7640 of 13287
I just got a popup notification for firmware update 1.7. Installing now. Wish me luck.
Any idea what this update is for?
post #7641 of 13287
Hmmmm. Well as much as I wish its for what we all hope I doubt its anything other than some minor bug fixes
post #7642 of 13287
Ok......I dont know if this is a placebo or I want to pretend its not there but I just did the update. Was previously watching something that I could clearly see pulsing and now.....I havent seen it yet..... Someone please try and confirm. I am probably wrong but.....
post #7643 of 13287
Maybe the new firmware disables LD
That would be good news if that is the case. I won't be able to confirm anything until later this evening, but even then, I usually watch in thx mode and don't notice any pulsing/flickering. I do have the soap opera and movie clips that show the pulsing in other modes, so I will try to test with those later (time and wife permitting).
post #7644 of 13287
LD is not off....so far I havent seen it in the one source I was watching before but I cant tell if my eyes are playing tricks on me. One thing I noticed is a slight more grain in the pq....hope someone else can confirm or deny with other material
post #7645 of 13287
Oh No! I'm at work!!! I'll be leaving soon on an emergency call ...
post #7646 of 13287
Yup. I haven't used the Pro 151 since I got the Elite. The 151 still has a great picture, but in my house it's redundant.
We may be moving, and at that point I'd probably get the 70" Elite.
post #7647 of 13287
I never noticed the pulsing before, so can't comment, but I don't see any more grain with 1.7. Using movie THX.
post #7648 of 13287
Update.....several different material....so.far I cant discern pulsing.....could they have really done it...
post #7649 of 13287
Firmware update today for the flickering issue... I got off the phone with Will from Sharp... He said it greatly improves it, but they will have a follow up update to enhance it even more...
post #7650 of 13287
Thanks for the info.
Sure would be nice if they posted up release notes for these updates.
