Originally Posted by broadwayblue
Honestly if I had a ceiling mount I would likely have already bought an AR100. But sadly, I have a small shelf on the rear wall that is only 14" or 15" deep. My old AE900 and current AX200 fit quite nicely, with a couple inches clearance behind for cables and the front of the unit just about flush with the front of the shelf. When I bought the shelf I incorrectly assumed that as technology advanced projectors would get smaller over time. lol I guess I can consider buying a 16" shelf, but if the unit is actually 15" deep I'm not sure I'd have sufficient rear clearance. How much does the lens protrude from the front of the unit? I could have that stick over the edge of the shelf.
CAD drawing of AR100U.
ftp://ftp.panasonic.com/pub/Panasoni...-AR100_CAD.pdf
I have my AX100U mounted on a 12" shelf. When I put the projector on the shelf, I realized that it was a little too shallow for the AX100U since there needed to be a few inches behind the projector to clear the HDMI and AC cables. My solution was to keep the brackets where they were, but move the shelf a few inches forward (so there is about a 2" gap between the shelf and the wall). I was just looking at the shelf yesterday to see if I would need to move to a deeper shelf or if I could still use my 12" for the AR100U. A 14" or 15" should be no problem if you can do something similar.
It has the features I need at a price I can afford. I would LOVE an AE4000U but can't find one at a price I can afford, even refurb units.
