AVS › AVS Forum › A/V Control & Automation › Remote Control Area › My Harmony 360 remote is on its last legs
post #1 of 11
More and more buttons have stopped working. I've opened it up but no amount of cleaning, poking, or prodding seems to work.
I have to bite the bullet and buy a new remote. But Harmony seems to have greatly jacked up their prices while removing features. I paid $60-70 for this remote a few years ago and it controls 12 devices and has a million buttons plus screen. Looking at the Harmony site, I now have to spend $200 to get a device that controls 15 devices; otherwise, I'm looking at 5-6 devices, which is not going to cut it -- I need a bare minimum of 7. I need to control a projector, a tv, two receivers, 360, PC (mimicking an MCE keyboard), Comcast cable box, and no doubt something else I'm forgetting right now.
Suggestions? I do like having the 360 buttons because they work well for the 360 and for Comcast remote features (onDemand, Guide, etc). I want to spend under $100. The Harmony One refurb for $125 could conceivably be tempting but with all the problems I've had with this remote (and other Logitech products), a 90-day warranty isn't going to do it for me.
post #2 of 11
FYI, you can use code "logi_h1_9711" for $25 off the Harmony One refurb to bring the price down to $99.99. But yea, you would still own a Harmony remote with a 90 day warranty.
post #3 of 11
Yeah, I'm just a bit baffled as to how a 12-device remote with configurable soft keys, activities, and 43 hard keys completely customizable per activity was only $60 or so five years ago and now there seems to be NOTHING as powerful for anything close to that price.
Anyone have any experience with this Philips? http://www.amazon.com/Philips-Presti.../dp/B003DNS88W
post #4 of 11
It seems like even the pricier ones like the URC R50 don't do what this Harmony did.
I need true Activities, not just Device macros. I have two displays and all the same devices going to each, so I need complete control over what is turned on and what every button does for each Activity. For example, I need one activity for "HTPC - tv" and one for "HTPC - projector", along with "cable - tv" and "cable - projector", with all the corresponding devices, inputs, and keys set up for each.
post #5 of 11
If you are trying to stay under $100 you are going to have trouble replacing a Harmony's features. With a Harmony you are trying features for build quality. They do a lot, but should be considered disposable.
You could grab a Monster AVL300 for cheap which has the guts of a Harmony 890 and has RF. The Acoustic Research remotes are also a pretty good value.
post #6 of 11
+1 on the Acoustic Research. I replaced my 360 with this 18 device remote for less than $70. It's similar to harmony in many ways minus device state tracking. On the plus side it has no macro limitations.
post #7 of 11
That's definitely in the running. My three candidates right now, along with the best prices (some allow me to use deal points gained at another site to reduce the price) are:
Philips Prestigo 6008 $18
Xsight Touch $56
URC R50 $61
Monster AVL300 - $54 -- thanks for the tip on the Monster
It's tough to decide since the manuals either aren't available or are trash.
I guess it's the dual displays that are the problem. Everything but Harmony seems device-based, but an activity based on, say "cable tv" just doesn't cut it because I need to be able to watch it on tv or on projector. I guess a workaround is duplicating the cable box device and setting one cable "device" for tv and one for cable, for example.
post #8 of 11
FYI, I received an email from Logitech for 50% off a single item. I have been given a supposedly unique coupon code. I have decided not to purchase anything with it so I will give it to the first person that PM's me (expires 9/14/2011). BTW, the 50% off seems to work for the new remotes but not the refurbs.
Jay
post #9 of 11
Jay
Nor does it work with the Logitech Revue which has recently been reduced to $100.
post #10 of 11
Gonna go with the Monster. Familiar Logitech-ish software, packed-in RF, etc made it the one for me. Came down to this or the URC R50, I'd probably be happy with either.
post #11 of 11
Got it today. Same old hassles with Logitech software, but it does everything I need it to. I don't miss the colored buttons really. And it's nice having 8 configurable soft buttons per page as opposed to the Logitech 360's four. RF is nice too although I don't need it at the moment.
Thanks to bryansj for the tip.
  Back to Forum: Remote Control Area
