It would help if we knew exactly what the the two RC sliders did. I would think that they vary terms in the scaling and associated noise filtering algorithms used by Sony.
The issue is how to observe exactly what effect these controls have on picture quality without knowing the forumulas and what these sliders vary with respect to those formulas. I suspect the formulas are very proprietary and will not be disclosed by Sony.
Now I suspect that there is no absolute correlation between how one should be set with respect to the other. Sony could have supplied only one slider and taken away user choice with respect to the other. It didn't but an inkling as to the relationship between the two is the defaults Sony uses for normal and high brightness operating modes (20/20 for normal and 50/50 for bright). An implied linearity in the setting of the two and the same sloping of the two controls with the same crossing of the axis. Yea Yea. Its probably not a straight line.
But what do these controls actually do? How should one adjust them for the input signal one is feeding the projector. One would think noise associated with the input signal should be dealt with the noise etc controls in the advanced operating menu and that the resolution and noise controls under Reality Creation are not dealing with the resolution of the input signal and not how noisy it might be. Of course I could be wrong but then again I could be right. I hope that covers the possibilities as to my thesis.
If I am correct, we would need several test patterns to properly adjust the controls, patterns for each input resolution such as 720p, 1080i, 1080p 24 and 1080p 60. Assuming I am right, then what would be an appropriate pattern or patterns?
Looking at content, it is hard to discern significant changes but selecting certain let's call them torture patterns, the controls have significant visable effects and some quite negative if they are what I will assume are not correctly set or rathe set incorrectly. A engineer/lawyer quibbling with language because I sure can tell what is a wrong setting but I can't determine what settings are optimally correct. There is another possibility that there is no correct setting and that either of the two controls depend on user taste but once again the proactive control would be resolution with no guidance as to how to set it and the reactive control, noise filtering, to make watcheable what havoc operation of the proactive control might cause. A noise control normally removes noise appearing as high frequencies (I feel this statement will probably attract varying degrees of criticism but I am trying to generalize and think this through). High frequencies are detail and throwing out some noise will undoubtedly throw out some detail. Theory versus what you can see. If you can't see the high frequency detail but you see the noise then probably it is OK to remove the noise and the high frequency detail as a consequence. Also some may not be as sensitive to noise as others. Its almost like the varying tolerances possessed by some AVS members to read posts containing significants amounts of drival such as this one on the slim outside chance that something of significance may be inadvertently stumbled on.
I still do not know what is an appropriate test pattern and how to use it to set the RC controls. A traditional resolution pattern such as Wolfgang was projecting with the Isco thingy in front of his lens? The one Randall posted?. I don't think so because they don't tell you much it.
I think on off pixel patterns might be more appropriate including ones that presented diagonal lines rather than horizontal or vertical. I don't have such a pettern but I can tell you horizontal and vertical pixel patterns are DRASTICALLY affected by operation of the controls, however the extreme havoc the let's call it improper RC settings have on these patterns doesn't always translate to havoc on normal content. In my experience operation of the sliders causes pink coloration in the patterns and in the extreme pink banding, however by operation of the noise filtering control together with the resolution control most the pink coloration can be eliminated. Also extreme operation of the noise control can cause severe blotching on the pattern. One click too much, but the blotching is not visable on content. At present, I use the pattern to set the cotrols to smooth the pattern slightly and set the noise control to give me good gray coloration of the pattern. Even here there is considerable range available and I have no means of determing whether noise at 10 or 20 is the better setting, but I can make all hell breaks lose at certain settings. I am being illustrative with my numbers, not reporting them exactly.
The cowards way out. Just leave them at the Sony defaults. Why the 50/50 for bright modes instead of 20/20 for less bright modes? Simply, the higher the RC sliders are set, the brighter the picture appears.
But, if you go to the actual review on their site, you can see for example that there's a test pattern with diagonal lines. With reality creation off, there's obvious stair-stepping. With it on, the edges are much smoother.
