Zombie,
I just got mine set up and watched a bit of 3D with a few others as we were comparing HDMI cables. I found it to be brighter then any 3D I've ever seen in a theater. I don't have my light meter right now but when Scopeguy brings it back during our meet next month I'll do some reading on the bulb at what ever hour/s it has on it at that time in both 2D and 3D. No Ghosting detected by any of the 4 of us on any of the scenes we used.
Also I have zero issues on the the PJ so far that I can see. I'll have Michael over for ISF calibration / certification next month so he'll confirm the unit is 100% at that time but for the quick tests I've done with the installers the unit is flawless. I have a few pics up in my thread.
Set up is "cave" with 138" 16:9 AT SMX (gain 1.0 to 1.1 ish). Projector is mounted at 16' back from screen and has very little in the way of "tweaking" such as lens shift etc.. it's just a couple of clicks on keystone and that is about it. Settings are cinema 1 out of the box and high lamp was only used for 3D.
Cheers
Calvin
Cheers
Calvin
