Mark, do you have any feeling about whether the 4K BD will be 4HD or 'true' 4K (I think you know what I mean).
Bill
Bill
Well that and to actually get a 1000, which isn't going to happen for now, 4K is just a bit too up in the air right now for my taste, well that and the price.
I'm curious what AR most of you use for HDTV. I cannot see any pq diff between 'Normal' (16x9) and '2.35:1 Zoom' (17x9), but would be interested if any of you can. (I CAN see some diff on some test patterns, but for the life of me I can't on any real pics.)
With the former AR (16x9) my screen provides a 128x72 pic, while with the latter (17x9) it gives 136x72. So since I'm addicted to size, I'm using 17x9 at present, but would give it up if I'm sacrificing any pq.
Doublewing11: Not sure who's older (I'm 71) but surely am having fun with all the HT business! Re screen size, it's very personal, and of course limited by your room situation. I really like the big screen/emersive experience, so got he widest screen my room could take, 144"W, and I decided that 72"H was as high as would fit. So I have full width for 2.35 pics (144 x 61), and full height for 16x9 (or 17x9 with the 1000), 128 or 136W x 72H.
Because of the size , for the brightness I wanted I went with a Dalite HP screen, the new 2.4 version (had a smaller earlier 2.8 version with a RS20 and loved it, so I had no hesitation about it). Works great in my situation because the 2 or 3 viewers are all near the screen center, and the projector is on a stand just above head height. But all of these considerations are things that one needs to think through carefully for their own setup. I have the Sony1000 at its min throw distance, which helps with brightness and also for the HP's retro-reflective character, so its very short min throw ratio was of critical importance for me. You need to get out your calculator and check out all he parameters for your own case.
