Originally Posted by Eternal_Sunshine
Cine4Home has a preview:
http://www.cine4home.de/tests/projek...00_Preview.htm
That's a bit more encouraging. The review states tha the projector can not process a future 4k signal at 50 or 60 hz. How much of a concern is it that the 1000, via its 1.4 hdmi can only do 4k resolution at at 24 or 30p? How much does this effect how future proof the 1000 is? If I purchase a projector for big money, I want to keep it for at least 5 years and not be prohibited from future 4k signals. Maybe field upgradable hdmi path? ...unlikely.
Cheaper versions of Sony 4k projectors will follow in future years, as Cine4 states, but not likely at the 1000's (hopefully) high ansi lumens, and certainly with a downgraded lense.
) , that the projector Cine4home has, is a newer and better version off the 1000ES - because it allready has far better data : on/off CR ( 500 K cal. -700 K uncal. versus 152 K ), better colors OTB, higher native CR ( 12 K- 20 K versus 2372
), more precise gamma and better scaling
