Originally Posted by
JMAUSGP
I will be very interested to see how you review different things on your Dalite Hi-Power screen. Especially what kind of 3D picture it throws. BTW, what size is your Dalite HP screen and is it a 2.8 screen?
I think I had the 2.8? But not really sure. I ordered it in June of 07 and dont remember there being a choice..
I had my rs20 set up perfectly hanging at long throw from the ceiling, but I dont have a mounting plate for the 1000, so its sitting on a table probably 5 feet closer than the rs20 was. But since I see my head in the picture now, I assume its in a pretty good spot for brightness
. Its a 133" diagonal.
It is too bright of course, but not WAAAY too bright, which is what I expected it to be. I hope this 1500 lumen number that Randall is getting doesnt turn out to be right. This will be going back if so, as I need every bit of the 2000 lumens promised when I get my 160" enlightor screen.
I also dont seem to have one of these "perfect" convergence units since I do see some red fringing. But I will reserve judgement on that until i can mount it since I have seen that change sometimes from shelf to ceiling mount with other projectors.
So far the black level seems pretty high, after I calibrated with my AVS disc. To see the flashing 17 bar output from my OPPO, brightness was set at 52 or 53. Gamma was OFF though... seems much better with Gamma on 2.4 or 2.6. I will measure gamma tonight hopefully.
I do see the IRIS working pretty often. I think the IRIS is set on AUTO full... I havent changed many settings yet.
The first thing I noticed when displaying a movie is how many skin imperfections I see all of a sudden on the actors, but I think some of them go away once Reality creation is turned off. Like I said earlier, Reality Creation seemed to make film grain unbearable and pronounced. Like a sharpness control turned all the way up.
