I'm about to start building a pair of ported 7.2 ft3 19hz tuned 15"s. Just got my woofers in today! I have everything but the amp, which is looking like an NU3000 DSP after some reassurance of its actual power output (600W @ 4ohm!) My situation is very different from most of you, as I like in Alaska, and shipping from PE is absurd. After looking into many drivers none here have considered, I settled on a Power Acoustik MOFO 152X. This was only $150 shipped from Amazon. While this is no world beater, it is an extremely well built 15mm Xmax 15", that models well in sealed and vented enclosures.
Edit: Plan was changed to a pair of 2.8 ft3 sealed boxes using O Audio 500W plate amps. Final pics on 2nd page.
Close up of the aluminum heat sink/cone stiffener
600 watts with 20hz HPF, excursion only hits 13.5mm
Will update with box construction over the coming weeks.
Progress was definitely slow, as the plywood is incredibly crappy. I pretty much just gave up trying to get the finish perfect and this is going to be as good as it gets, I've been sitting on these too long and I still have 5 speakers to build
