I have some old VHS and VHS-C home movie tapes I want to definitively preserve and I'm having a hard time deciding which transfer route to take. I'd like some advice for the best yet most sensible method. From what I understand, I have three options. The first two would be DIYs:
1. VCR to DVD combo. I own an LG LRY-517 and thought about buying a 100 pak of Taiyo Yuden 16X 4.7GB Silver Thermal Lacquer DVD+R and just dubbing it in XP. This is my most sensible method however, I'm not as certain this is the highest quality method. I noticed it dubs at mpeg-2. From what I understand, transfers can go even higher to mpeg-4, or 10 bit uncompressed.
2. VCR to PC transfer. This has been a little more difficult for me to figure out. There have been a number of ways, devices to use but I haven't found the perfect ones. I'm not very technical but I'd be looking for like a firewire or component wire connection from a VCR to a USB or firewire connection to PC. I've looked at devices like Blackmagic Video converter,
Canopus ADVC, Elgato video capture device, but for me it seems like there are quality or technical issues that makes this hard for me to decide. I don't even know what will happen when I connect a VCR to my computer. And I haven't even begun to research software. My current VCR doesn't even have firewire but would consider buying a new VCR with such a capability.
The last option would be to go to a professional transfer house.
3. Media House Transfer. I live in LA so this would be the easiest but probably also the most expensive. I get quotes from $55/hr (Yale film) to $250/hr(HD pro8mm). With 7 VHS and 15 VHS-C to transfer, it'll be costly. But I can easily get 10 bit uncompressed digital files and probably my best bet for the highest quality transfers.
I do want the best transfer, but I want to know if I can easily do it myself for cheaper, and if I'm just obsessing over cable connections and file types that won't make a visual difference.
On a related note, I also have a bunch of Hi8 and Video 8. Does a DVD transfer capture this resolution? Would a s-video to pc be doable and sufficient?
