Figured i'd post some pics of my recent surround build.
They were a low budget, low effort affair. I just needed something to replace my ugly rear channel satallites.
I looked through Zaph's speaker reviews for a small driver that was suitable for full range operation. The Fountek FR88EX rated very well and was recommended by several people on this forum. Unfortunately, the price had just jumped significantly on those drivers and they were out of stock from Madisound. I chose the Aurasound NS3 as a substitute because it was in stock and Zaph mentioned it *could* be run without a filter and i'm lazy
I wanted the box as small as possible. I chose a sealed design 6"Wx5"Dx7"H
that will produce a Qtc of 0.74 according to WinISD and result in an F3 around 95Hz. This was larger than i wanted to be perfectly honest, but i went ahead anyway.
Because i thought i may change drivers in the future and i was going to play around with different approaches to veneering the front, i went with a removable baffle.
I had some time to listen to them before i started on the veneer and they were a big improvement over the tiny old satalites they replaced. I think i have some air leaks after the veneer work because the baffle does not sit flush anymore. i haven't listened to them and will probably disassemble and do some sanding to get them fitting better before i have a finished product.
Edit - these are nothing special, but i figured i'd share since i like seeing picks of other people's builds, regardless of the complexity or level of quality...
the bottom of one of the boxes started buckling and splitting.
So i'm atttaching these more as a refernce point for when i have some time to hook up a CD player and retest.
