Hi,
I would like to "hide" one or two subs in a new fireplace hearth under construction. The hearth is 16" x 16" x 108" long finished. The sub(s) must open out the sides of the hearth. It will be made of 3/4" plywood with a 2" stone top and faced with 2" stone on the front face, so I only have about 13 inches to work with for the opening. I have read DYI sub sites and the calculations are too complex for me, so I am asking for help / suggestions. Should I buy pre made subs and put them In the openings or buy the sub parts and install on each end? I could get bigger ones if i build it myself. Either way, I need specific part info or model numbers.
My only other options are to cut into a wall (which will get me in big trouble) or hide one in plain site somehow.
I normally use a regular receiver to drive the surround system. Thanks in advance for you help.
Dan
Dan
