Originally Posted by
atmusky
I facts seem to be hard to follow on the PSIP data issue so I want to make sure I have it correct:
- On the CM 7400 PSIP data does not automatically update. To have the PSIP data updated for a channel the CM 7400 must be tuned to that channel.
- When using the PSIP data only (no paid guide) after the PSIP data runs out name based recordings will not record.
- How fast PSIP data runs out is channel specific and can very greatly.
- Time based (manual recordings) will continue to work even if the PSIP data runs out.
Is the above correct?
atmusky
I don't really have any questions about PSIP data in general or any specific issues with what any station is doing.
The questions in my last post (
#1248) are specifically about how the CM 7400 is functioning in regards to updating PSIP data and what that means for using Name based recordings.
Hmmm, I thought someone would have given you a direct answer.
As far as OTA is concerned the prevailing observations say your summary list is correct for the free PSIP guide.
So far, one person has made the observations of #1 & #2 because he has had occasion to not turn on his unit for a period longer than the length of a channel's guide and missed recordings because the guide was not populated. He says he now scans the channels every morning to manually update the PSIP guide and make sure it's populated for the day -- he reports no further problems. It seems everybody else uses their units daily and so have not run into the PSIP guide not updating automatically. Apparently, if there is no data in the guide, the recording does not even appear in the schedule.
#3 is true in general. When I was playing with PSIP information I found most channels provided 8-24 hr worth of data. I did have two channels that provided 2 days worth of data -- quite exceptional.
#4 for manual recording is true. However it appears that the recording will only be labeled with date/time information regardless of whether or not PSIP information exists in the guide for that time-slot. Still, if you are going away and want those recordings, that is the way to do it.
