AVS › AVS Forum › HDTV › HDTV Recorders › Channel Master TV CM 7400 HD DVR - OTA, Clear QAM, Internet Content
Channel Master TV CM 7400 HD DVR - OTA, Clear QAM, Internet Content - Page 63
post #1861 of 1939
Originally Posted by northernlight11 View Post
Sorry of this has been asked, does Pvrexplorer pro work to offload recordings like on many other of the dish boxes?
if you mistakenly asked about CM7000-PAL, just discussed last week in that main DTV pal dvr thread
post #1862 of 1939
I am just starting to look into other dvr's and have not looked through all the threads yet, I was just wondering if you can offload your recordings, since it seams very similar to the sat boxes which also seam to use a the same or simpler file system I was just curios if Pvrexplorer pro worked with it also
post #1863 of 1939
post #1864 of 1939
if you still interesting in the CM7400 model, look at post#1007 otherwise, see other thread [DTV pal DVR].
post #1865 of 1939
The CM-7400 isn't a Dish/Echostar box like the CM-7000 was. The 7400 uses a standard Linux file system.
post #1866 of 1939
Sort of ... not compliant actually. See additional info around post#1007.
post #1867 of 1939
Originally Posted by dxjnorto View Post
These Dish-like remotes are sensitive to background IR, like from a plasma TV. Try moving your 7400 lower in your rack or something. Hope that helps.
Nope, that is not it, the 7400 itself after given a command by the remote more often than not, reacts to the command about as fast a drunken snail, you always get that stupid little animated asterisk type "wait" icon that reminds me of the annoying Windows hourglass "wait" icon. It has nothing to do with it being a Dish like remote, I also have two other devices placed both to the left & right of the 7400 that do in fact use actual Dish remotes, and they work just fine.
post #1868 of 1939
Originally Posted by kesov View Post
my problem is solved.
I also use my CM-7400 with the local cable provider. You'll probably find like I did that it's a good idea to 'Restart' yours daily. Not only keeps pic quality better by causing the tuner to (I imagine) re-acquire the signals, but if signal quality is diminished these units often will skip scheduled recordings.
Regarding the cooling issues, in a previous post I mentioned that if your unit isn't enclosed in a cabinet, one solution is to get a small 'face fan', 6" or less, the type that has a clamp attached, and position it in such a way that it's blowing across the 7400 case. Mine's been operating at ambient room temp for nearly a year now, and while I still have occasional problems (mostly related to using it with a QAM cable source), they're mostly minor.
If you're subscribing to CM's PPG upgrade, you'll notice the remotes become mostly useless for about a minute once an hour when the unit connects to update the guide.
Edited by BenCartwright - 2/15/13 at 2:03pm
post #1869 of 1939
Will that work better than a laptop fan with usb connection?
post #1870 of 1939
Will work better, if you'll open a cover; adding the fan would be best with open cover, or its angled position at least.
post #1871 of 1939
Certainly.
Run anything off the unit's power supply via USB and you increase the power supply's work load. While the net result is a cooling effect, there's not much better a way than cooling the whole damn unit, case and all. Mine runs about 1-2 degrees above ambient room temperature measured with an IR gauge on the top of the 7400's case, about a 40 degree drop.
Edited by BenCartwright - 2/15/13 at 6:06pm
post #1872 of 1939
I'm trying it now with the laptop fan, since I already have one. I haven't tried it without, but the temperature reading at the top of the case is 80F. I don't plant to keep it plugged in all the time either, since I like to save energy, just because.
post #1873 of 1939
Per a reference on the "The Official AVS Dish DTVPal DVR Topic!"....
http://antennalogic.ecrater.com/p/17040669/entone-dvr-dual-tuner-for-antenna
It's also on ebay from them.
Entone Amulet 458 Hybrid Dual Tuner DVR
(Same features and operation as Channel Master CM-7400, but with a welcomed 3 speed menu selected internal chassis fan.)
post #1874 of 1939
You should start a thread. Don't forget:
Electronic programming guide and TV guide functions
Tuners
• Dual ATSC Tuners for antenna HDTV
• Clear QAM
Hybrid Tuners
• Dual ATSC
• QAM Cable
Really, start a thread. "Entone Amulet 458 Official Certified User and Owner Thread"
You do know that Entone wrote the firmare for the CM7400?
Edited by JoeKustra - 2/26/13 at 4:55pm
post #1875 of 1939
Is it actually a separate device? Judging by the pictures, it looks like a rebranded CM 7400 with a hole drilled in the back of the case for a fan, combined with a blue power LED, instead of the CM 7400's green one. Even the remote control is the same, except with a different logo at the bottom. Perhaps the CM 7400 -> Entone 400 relationship is the same as the Dish DTVPal -> CM 7000 relationship?
post #1876 of 1939
Entone makes the 7400 for Channel Master. Search this thread from about year ago.
post #1877 of 1939
Ebay post indicates no optional guide:
Note: This unit does not have the premium program guide available, (14 day outlook, 50.00 per year subscription fee/ like the Channel Master CM-7400 DVR.) We find the typical 7 day epg (electronic program guide on this Entone unit more than adequate
Yeah, right.
post #1878 of 1939
Is the CM 7400 still being made/sold? It disappeared at Fry's quite a while ago, I noticed Amazon states it may never be back and Channel Master itself says it's out of stock... doesn't look good.
post #1879 of 1939
Another reason for a new thread.
post #1880 of 1939
Yeah, right.
That's the first thing that caught my eye when I looked at the linked specs. No optional subscription guide. What do they mean by "typical 7 day epg ". Probably just PSIP, what else is there. If it is PSIP, remember all the reports in this thread that the CM-7400 does not scan the channels on its own to update the PSIP info. Does this one?
CM-7000 = PSIP + TVGOS
CM-7400 = PSIP + subscription guide
Entone 458 = PSIP + no guide option
Looks like they are marching steadily towards manual VCR style programming while maintaining a very stiff price.
post #1881 of 1939
Entone made the Channel Master 7400 branded version. So I wonder if this model uses the same weak/problematic tuner? The major improvement with this Entone model seems to be the added fan to prevent overheating, but if it has the same bad tuner it is still a poor choice for me. I still have a 7400 that will not decode most of my major channels that my other tuners do.
post #1882 of 1939
My complete guess is Channel Master's exclusive contract has expired or they punted and the new guys don't want to bother with the guide service... sell off what they have in stock or what they can throw together.
post #1883 of 1939
It would be interesting to see, if the DVR will follow a path of TR-50/CM7k-DVR when ROVI cut TVGoS nationwide and left owner with short PSIP guide. How long the CM7400 EPG subscription will be supported ?
post #1884 of 1939
Ii posted this several weeks ago and after a reboot it went well for a few weeks but i am back at: I have a channel master cm 7400 for about 4 months now. The problems I have are: My channels are again coming in very disturbing and glittery. I did have this a few weeks ago. The channels come in very clear on my tv thought the tv tuner. I even tried to connect the cable directly to the cm 7400, still glittery. So it must be the tuner cm 7400 itself. Any new suggestions?
post #1885 of 1939
Buy or build a bigger antenna? The CM 7400 has a notoriously bad tuner.
post #1886 of 1939
post #1887 of 1939
The CM-7400 is currently out of stock from Channel Master, but may not mean it is being phased out. Could be their stock is empty and they are awaiting a new shipment from Entone. As they still have their Channel Master TV support site and still offer the extended guide/subscription service. So hopefully if their is a new batch it will include the updated version with the cooling fan. And would be nice if it has a better tuner. And they have also been out of their new CM-7777 preamp, but are supposedly awaiting a new supply. They truly need to do a better job of maintaining inventory of their major products.
post #1888 of 1939
Hey guys. Super newbie here. Wondering if anyone has a dumbed down guide to installing the eSata on the CM 7400 and wouldn't recommending which eSata model to buy and exactly what you need to install it. Thanks!
post #1889 of 1939
OK. Here is:
1. buy eSATA enclosure with a drive of your favorite size
2. turn off DVR and the enclosure's power supply
3. connect eSATA cable to the DVR.
4. turn on enclosure's power brick, then the DVR.
Done.
post #1890 of 1939
Ok. Sounds simple enough. I've seen multiple posters recommend this eSata :Thermaltake BlacX ST0005U Hard Drive Dock - 2.5"/3.5" SATA to USB 2.0, eSATAItem#: T925-1252 | Model#: ST0005U. Since it's just the dock you also need a Hard Drive Disk correct? Any recommendations for which one to buy or does that not matter as much as the dock?
  Back to Forum: HDTV Recorders
