This is my first post here, so be gentle!
I'm very close to making the decision to buy the Canon AX10 but want to get some more opinions about how it ill suit my needs.
I had a Sony handycam that was 10 years old and loved it, but it died a while ago and now its time to replace it for home use and also for some business possibilities.
I'm going to start shooting some weddings so I need something that works well in low light, is HD, easy to use and has good audio options.
My wife is a very successful (wedding) photographer and uses Canon 5D MKII's but I'm not keen to use one for video because of its audio limitations and battery problems, and to be honest being from a TV background I'm much more comfortable with a dedicated video camera.
So my biggest concerns are how well the AX10 works in low light and what directional mics and compatible radio mics are available for it, although I don't think that's camera dependent...I like Sony (mainly because I've had one) but nothing they offer seems to compete with the AX10 for price and features. The VG10 is a consideration but the interchangeable lenses might become more of a hassle compared to a 'fit all situations' fixed lens, and the mic looks good but I worry how good it realty is compared to a separate mic.
I'd like to find out how well this little camera works for shooting weddings (ie Low light) how well its audio options stack up and what other cameras I should/could consider?
Cheers
Cheers
