Hi all,
So I just got my panny ST30 and i was wondering for the total amount of time it would require for both break-in period + pre-panel period for calibration period wouldnt that entail an total of 250-300 hours? Because using te pre-panel from D'nice's settings he had said not to use his pre-panel as an substituion or a break in method meaning youd break-in the image first (using default factory settings(?)) For 150-200 hrs and than use D'nicest custom settings for the pre-panelling, and pre-panel for another 100 hrs (if i remember correctly) then for the final result of calibration?
Could someone help me confirm this-as I've done extensive research and this seems like what it means.. first HD TV plasma though.
Also about gaming, within the first few 100 hours if you do casual gaming on an hudless movie like game such as Heavy Rain, would that be alright? Because I know for.the break in period you need to avoid games but that's usually referring about the huds used intake which could cause.burn in and retention.. so I'm wondering about an hudless game like Heavy Rain. :/
