AVS › AVS Forum › Video Components › Home Theater Computers › XBMC IR options
XBMC IR options
post #1 of 5
I have a Windows HTPC running XBMC, and I'd like to control it using my Harmony remote. I'm looking for suggestions for IR receivers that I can use - or IR receivers that come with MCE remotes.
Came across this one - anyone have any experience with it? Good, bad? Other suggestions?
http://www.amazon.com/Windows-Contro...p_ob_e_title_0
post #2 of 5
That would work, but you don't need the remote since you have a universal.
The HP Media Center IR Receiver on eBay works well and can be purchased for ~$10 shipped.
post #3 of 5
Thanks Bryan, I'll give that a shot.
post #4 of 5
Just to close this out, got my $10 IR receiver (eBay), set it up, and everything is working great. This was a useful thread to get me started (key mappings):
http://forum.xbmc.org/showthread.php?t=54466&page=19
post #5 of 5
Look at this if you haven't already. Lots of Harmony codes for the MCE remote.
http://forums.logitech.com/t5/Harmon...ur/td-p/374844
