Originally Posted by
N8DOGG
I know it's a preference thing but what I'm getting at it exactly that. you guys can't assume that your preferences are what everyone else wants/likes, it's just not the case.
Preference doesn't really come into it for me. I am striving for a
reference result. Once I am sure I have achieved reference, or as close as I can get to it in my room, then I raise the sub level by 3dB. That's it. I don't touch anything else. I am, IOW, completely happy with the way Audyssey EQs my room and system, but I prefer a little more thump from my bass (this is for movies only). I could never listen with Audyssey off, because the sound in my room is then unlistenable-to. As to other folks' preferences, well I don't care. It's up to them how they adjust their system in their room - it's their room, their ears, their money etc and whatever makes them happy is great by me. When I comment in the threads here, I am only trying to help people use Audyssey in the way it was intended to be used, as I understand it, and to help them achieve a reference calibration. I'd never presume to tell anyone how they ought to use their system. I think that goes for most/all of the other regular posters here too. Once reference has been achieved, then preference is fine (as Chris used to say often).
N8DOGG
I've listened to peoples rooms before I've done the pro calibration and thought it was horrid and after, thought it sounded great but that doesn't mean thats what owner thinks, who knows what they may do to it after I've left.
I'd say that was entirely normal. You can only do what the program is intended to do: achieve reference. If someone doesn't like reference, then that is preference and is fine, for them.
N8DOGG
Too many people take for grantedroom correction and think it's the holy grail but it still has a long was to go. Have you guys ever done an actual measurement after audyssey is done? lol, it's usually not even close to the graph they estimate but most of the time, it's still an improvement from what was there before. Whether that sounds good or bad for the user is up to him.
I don't see any disagreement between us on this. You are simply saying that some people have preferences which they prefer over reference. That's fine.
The main issue I have is that you have said that with certain types of speakers, Audyssey cannot achieve or approach a reference result. To me that means there is something wrong with the technique used (possibly), or the room is so utterly bad that nothing can improve it (unlikely), or that you have found an as-yet undiscovered bug in Audyssey when used with very efficient speakers (interestingly). If it is the latter, it's something I have never heard of before - there are many people in this thread and others who use horn speakers like Klipsch etc and who have used Audyssey with great success.
What I
really think <<img src="
http://www.avsforum.com/avs-vb/images/smilies/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" />> is that you just have a strong preference for a certain type of sound and when Audyssey removes that type of sound, you dislike the result. That is fine too of course, but it isn't an Audyssey problem.
I have a friend who has some (fairly old but expensive) JBL speakers in his stereo system. He absolutely loves the sound they make. To me, they make everything sound like a disco. They are way from reproducing the source anything like accurately, but he totally loves them. I can listen to them for about 10 minutes and then my ears start to cave in. But he loves them, and really that is all that matters.
