Originally Posted by
kbarnes701
Hi Terry.
Yes you can test it without using Direct mode. Make sure you have Source set in the Input Output Assign menu. I think you do already.
Then go to Source Settings menu and go to Picture Adjust. On the Resolution setting, move through the settings until you get to 'Custom'. In that section make sure all the settings are at default but set Res to THROUGH. Back out of the menus.
Now put on a disc and find a screen with a fair bit of white content on it. Pause the disc at that screen.
Then go into the Home menu on the remote and click down to Video. There you will see that you can now switch modes from Through to Direct, Custom etc. What you need to do is first select Through and note the colour of the white part of the image. Then scroll along to Custom (where you also set Through, so it should stay the same) and you will see the white area of the image go whiter. IOW, the colour balance will go from warmer to cooler.
Custom is passing it correctly (as is Direct) and Through is giving a warm bias.
If you see the difference and you want to stay with the 'purer' white colour balance, simply select Custom in Picture Adjust for that source for future use. Make sure you have all the other bits of the custom setting set appropriately (probably all defaults).
Let me know how you get on. I'd guess this is something Onkyo can fix with a FW update once they acknowledge the issue.
EDIT: you may prefer the warmer balance of course. That's why screens etc have colour balance settings. But if your display has been calibrated, and I am guessing it has, then you will want it to be spot on I'd think. I mentioned before that I preferred the warmer tone, but I was using Hugo as a test disc and that has a lovely golden cast over much of the photography in the film and the Through setting enhanced it. I have since made sure I am using Direct for all relevant sources.
Keith, ... Well last night while watching something it just happened to come up with really Large Bold White Letters and I decided this would let me test the image for Whiteness.
This was on Dish HD watching CSI Miami.
I also tested this then with a Blu-Ray Disc, WOW ...
So the one setting (Input Output Assign menu) was "Source".
Then went down to picture and changed it back and forth between "Through" and "Custom".
This might Surprise you and it is going to not be easy for me to put into words but this is what took place.
The "Through" setting is like a (Softer, Dimmer, Off-White) sort of White Image.
The Runco produces so much Light that I did not know it was not as White as it could be.
If I had not read here about the effect of the "Through-Setting" I don't think I would ever have picked up on the image not being Totally-Brilliant-White.
I'm not intending here to Brag about the Runco but trust me it produces a great deal of light.
The {Custom} setting immediately with my Runco VX-11d just goes Crazy-White on the screen.
The Runco VX-11d is a Light-Engine .........
It is so much "Difference" that the image actually in {Custom} is just "Brilliant" to the eyes.
It was such a difference with my Runco producing the Light-Output it does you had to adjust to the New {Custom} setting.
I got the wife up there and did the Test between the two settings and she could not believe the difference.
So, thanks guys for the information on here regarding the settings on the 80.3 in reference to the "Pure-White-Image".
Mine will be on {Custom} forever !!!
Once again I am not on here trying to sell anyone on the Runco.
I use it in reference to why I did not even realize the image I have been looking at was not Totally White.
Terry
