I'm curious what everyone's opinion is on bi-wiring. I have a Sunfire Cinema Grand Signature Series II 5-channel amp. Each of the front channels have two pairs of outputs, one labeled "Voltage Source", the other labeled "Current Source". The Current Source is meant to mimic the sound of a tube amp. Whether or not it does, I don't really have the experience to say.
The manual suggests bi-wiring the fronts if your speakers have dual binding posts, which my Axiom M60's do. The front Voltage Source outputs of the amp are connected to the woofer of each front speaker, while the front Current Source outputs are connected to the upper range of each speaker.
I am pleased with the sound, but I haven't really experimented with different configurations. Anyone have any thoughts on this set-up? Is it as much hocus-pocus as passive bi-amping?
) the only difference in the two signals is a 1ohm resistor on the Current Source output that created an additional 1 ohm impedance on that set of binding posts.
