AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Integra DHC-80.3
Integra DHC-80.3 - Page 96
post #2851 of 3737
Originally Posted by spike9876 View Post
I was thinking about getting a Squeezebox Touch and possibly getting a DAC and use analog outputs... But I currently have a 5.2 HT setup.
In this scenario, is it recommended to go direct from Touch to Integra directly via digital cable ?
I wanted to get the best sound possible but don't know if I would achieve better sound with an external DAC on a 5.2 setup ?
I remember seeing a post about a DAC and a Sqeezebox so you may search for that. I am not familiar with Sqeezebox, is it standard lossless, compressed or less likely high rez? If MP3 I would doubt better DACs than what come with the 80.3 would make a difference but that would be a guess.
post #2852 of 3737
I have an 80.2 with a Sonos zp90. I have an Emotiva dac with balanced outputs. I can not tell the difference between the dac in the Integra vs the Emotiva.
post #2853 of 3737
I also heard that a separate DAC may not make a difference either... But wanted to check here as well...
post #2854 of 3737
Here's one for any computer audio users: Has anyone been able to play music from their computer, using WASAPI, and not have the Onkyo/Integra miss the first 2secs of each song while it identifies the format?
I've tried Foobar, WMP12 with reclock and jRiver Media Centre using WASAPI and WASAPI event style. I've even tried setting JRMC to play a few seconds of silence at the beginning. Every time I begin or skip a track, the Onkyo will take some time while the relays click in and I miss the start of each song.
Has anyone found a solution to this?
post #2855 of 3737
Originally Posted by hidefpaul View Post
Hi guys, just wondering if anyone has tried using the USB connection in the front of the 80.3 to play an .AVI file. I downloaded season 1 of "Sons of Anarchy" on to my USB stick as (.AVI files) however I could not get the 80.3 to play the movies. When I used my Oppo 93 the USB and the files played perfectly. IS THE 80.3 NOT ABLE TO PLAY movies through its USB inputs? I checked the manual but I did not find any video supported formats for the USB inputs, I only found the audio formats.confused.gif
Paul
Does anyone know????
Paul
post #2856 of 3737
Paul
Paul, one thing to note is that AVI is a "container file format" - many different audio and video codecs can be used inside of AVI files, so they typically can't be played on anything other than a full computer (even then you may need to download a CODEC package to do so). I don't know what video formats the 80.3 is capable of playing, but you'd probably have better luck converting the file to an MPEG or DIVX.
post #2857 of 3737
Thanks JHillyerd, I will try converting the file as you mentioned.
Appreciate the input.
Paul
post #2858 of 3737
Just an FYI updated firmware via Net for the first time since i got the 80.3, pleased to report
my 80.3 did not share Viking 1's fate. Just like on other modern electronics, all settings were
retained. Phew, i remember the pseudo-brickings and nights up with the serial port updates
on my previous Onkyo/Integras.
So far no breakups on the R High channel, keeping my fingers crossed, as you may have
read earlier i had a problem with random cutouts from R High.
post #2859 of 3737
Paul
I have strong doubts Paul about video files via dnla or direct usb . Most reviews list audio only files like flac or mp3 .Denon avr's /pre pro's are constrained as well .. Multichannel audio file playback is another area brands could improve ; 2ch is de rigeur for many ; the 80.3 hopefully not ?
I play these video files through my oppo too ; the qdeo does a great job with bitstarved lower rez avi files ;m2ts bd are wonderful smile.gif
post #2860 of 3737
Thanks cwt, I have resorted to using my Oppo 93 for these USB movie files. You are correct, the QDEO chip does an amazing job on the SD content.
Paul
post #2861 of 3737
Set -Up Technical ?
Why can't I select from all the listening modes when playing a BR.DVD? For example I can't select DTS or Dolby Listening Modes from the remote or processor even though the BR disk sound selection is set to DTS-HD- High Resolution audio . I have a 5.1 system but I should be able to select different Dolby and DTS listening modes. The best I can get is the Onkyo DSP listeng modes and Direct, Stereo Mono and Multichannel modes on page 39 of the mannual but can't access the modes listed on pages 40 and 41 of the manual!mad.gif
My old Sony receiver used to automatically decode the listening mode to the source options. Is there a way to have the 80.3 decode whats on the BlueRay disk and just play it? If the audio option selected on the disk was DTS-HD it would play in the mode, unless I changed it manually.
Edited by YES90125 - 8/12/12 at 2:04pm
post #2862 of 3737
Opps agnore this post. Still have the problem.
Edited by YES90125 - 8/12/12 at 1:56pm
post #2863 of 3737
If you plan on passing any DD 5.1 audio from one of the TV's smart apps to the AVR, you can only do that with an optical cable on the Panny TVs as only PCM 2.0 will pass over the HDMI(ARC) cable to the AVR.
post #2864 of 3737
Sorry had to delete that post as it was related to a seperate issue
post #2865 of 3737
Originally Posted by YES90125 View Post
Set -Up Technical ?
Specifically, which DSP modes do you want to get but can't?
Also, I don't understand what this means: "If the audio option selected on the disk was DTS-HD it would play in the mode, unless I changed it manually."
post #2866 of 3737
Set -Up Technical ?
Recalling my old onkyo Yes the 80.3 most probably does the same ie switch automatically to the dsp mode given a specific dts/dd/lpcm input .This s&v review bit clarifies ; no direct keys ;multifunction ones instead smile.gif Look for ''listening mode presets'' or similar in the menus ; its in there somewhere mate biggrin.gif
My more substantial complaints concern the paucity of direct-access controls via either remote or front panel. For example, you select surround modes via keys labeled Movie/TV, Music, Game, and THX, each of which steps through the programs that Integra considers relevant to those genres. But this still means that if you want, say, simple stereo, you may have to step through as many as eight other modes using the Music key; there’s no Stereo key per se, nor one for DPLII, Direct, or any other single mode. You can, of course, set up the default listening mode to be recalled with each input on the Integra’s main menu
post #2867 of 3737
Yes, i guess that is my concern and complaint. The display does not show all direct listening modes available when switching or when using the the select buttons for listening modes-- Movies/TV - Music - Game, The display appartently decodes the source and simply displays "Direct" "Stereo" "Mono" or "Multichannel" For example, when puting in the concert blue ray video RUSH- Snakes & Arrows the audio options on the disk allow for PCM Stereo or DTS-HD, If I chose DTS-HD, the 80.3 Processor doesn't show DTS-HD on the dispaly screen or anywhere else, it simply displays the listening mode as "Multichannel" I guess I am to assume that it correctly is decoding in DTS-HD correct?
I guess that by setting the Listening Mode Presets in the Set-Up Menu to "Straight Decode" for the source is the best option to correctly decode what is selected from the audio options from a Blue Ray Disk correct?
post #2868 of 3737
If it says multichannel, there is a great likelihood that the Integra isn't decoding it at all but that it is being decoded in the player/source.  How are they connected?  How is the player/source set up?
post #2869 of 3737
SCORE tongue.gif I am using a Playstation 3 connected by HDMI. After reading this post, I went into the Video Setting Menu of the PS3 and selected
BD/DVD Auto Output (HDMI). It was set to "Linear PCM", so i changed it to "Bitstream" and..presto.. the processor displayed DTS-HD Master when I played the BD disk. The sound kicks some serious a&&
post #2870 of 3737
I think you are getting confused with various things here. The unit will show all the available listening modes when you cycle through. Availability of listening modes depends on various factors - there is a list of these in your 80.3 manual.  For example, some modes are unavailable depending on your speaker configuration - check the list for details.
Next up - If you select a DTS-HD MA disc and your 80.3 displays 'Multichannel' then you have set your source to do the decoding and it has already been decoded by the time the 80.3 gets it, hence the display. Go into your BD player menus and set the Audio to 'Bitstream Out'. If you send the bitstream out then your 80.3 will decode it and you will see DTS-HD MA or Dolby TrueHD etc light up on or 80.3 display. It makes no difference where you decode it so you are not doing it wrong - but if you want the reassurance of seeing the correct lights on your display then send it bitstream.
Third, Listening Mode presets don't have any effect on the codec used. They are there so that you can set a listening mode (DSP) - eg Dolby PLIIx - when the unit detects an incoming type of signal. For example, if you have a 5.1 system and you always want any source in two channel stereo (2.0) upmixed to all your speakers, then set PLIIx next to Two Channel Stereo in the Listening Mode Preset and every time your unit detects a 2.0 source it will automatically upmix it to 5.1. In my system, for example, I use Height speakers in a 7.2 configuration and mine is set so that Dolby TrueHD, DTS-HD MA, Dolby Digital and DTS always use the Height speakers - so my listening mode preset for those source signals is set to PLIIz Height for each one. It saves you having to select a DSP mode manually each time that's all.
If you set Straight Decode as the Listening Mode Preset then that is what you get - when the unit detects the source signal it outputs exactly that, with no DSP applied.
Does this make things more (or less) clear?  I'd suggest you a) read the list of DSPs in the manual and check their availability there for different circumstances, b) set the BD player to Bitstream Out and c) set the Listening Mode Presets to however you like them in accordance with the advice above. If you still have questions after doing all that, then come back and ask again.
post #2871 of 3737
Use the HOME menu button and select the DSPs there - you can choose the one you want without having to go through all the others to get to it. It would be impossible for Integra to have every DSP on a direct-access button - there are too many. You can program a universal remote to each DSP though if you wish if you get the list of Hex codes.
The above is why Integra have provided the Listening Mode Preset option - so you can select your favourite DSP for any signal type automatically - see my earlier post.
post #2872 of 3737
Set -Up Technical ?
It's clear now from re-reading this post that you are decoding in the BD player. Set it to Bitstream Out and most of your issues will vanish.
Your BD player is connected to the 80.3 with an HDMI cable, right?
EDIT: just seen your reply to Kal. Has this sorted things for you? Can you now get the DSPs you want?  Are you clear now on what Listening Mode Preset does?
post #2873 of 3737
Does anybody know how the zone 2 & 3 sub outputs work? Is there a way to adjust the crossover, etc...? I have looked through the manual but cannot seem to find anything.
post #2874 of 3737
I tried searching this thread but I'm not sure if I found the info I was looking for. Does anyone know if the 80.3 has the capabilty to use an HDMI video source and assign an analog audio source?
post #2875 of 3737
While I've not personally tried it, the answer appears to be "yes". See page 63 of the manual. The audio selector can be set for each source and when there are both digital and analog sources, you can give priority to the analog source.
post #2876 of 3737
That rings a bell keith ;very handy when decoding in the player to lpcm or bitstreaming ; I recall the dtr 10.5 listening mode preset had 2 settings for 2ch pcm > 192fs sampling rate and one for lesser sample rates [if thats still available?]. Those times no 24/192 files around so couldnt test it at all rolleyes.gif
Remember setting dd ex when dd5.1 was received ;just to use the back surrounds smile.gif so easy and as you say obviates the need for direct buttons.
post #2877 of 3737
Something very interesting happened yesterday. I popped in "The Hunger Games" on Blu Ray last night with a bunch of friends over and usually when a blu ray/DVD etc starts up, I heard the sound and it takes a few seconds for the picture to pop up. Yesterday, I had sound but no picture. My TV said "No Signal." I had to turn the 80.3 off and back on to get the picture. Once the picture was back, I noticed the audio and video was WAY out of sync. I synced up the audio and video a while ago at about 60 milliseconds. I had to delay the audio to 225 milliseconds to get the picture and sound synced again after this happened! So basically, it went from a 60 millisecond delay, to a 225 millisecond delay. I have all updates for my 80.3 and Oppo BDP-93 Blu Ray player and I have tried different blu rays to see if the delay was only with this particular movie and it wasn't. What do you guys think happened here???
post #2878 of 3737
Hi there Blackdevil77, I too have the same set up (80.3 & Oppo 93), I rented "The Hunger Games" last week and had no problems with audio or video. Check your HDMI cables first, I would make sure to do a re-set of all connected components, ie. unplug your TV , the 80.3, the Oppo93 and all other equipment. Wait a good 30sec to a minute plug everything back in.
Hope this helps.
Paul
post #2879 of 3737
Just wondering if anybody has any info on this. I have searched and searched but cannot find anything.
post #2880 of 3737
Hope this helps.
Paul
I just did the reset and checked over the HDMI cables and no problems. Still same problem. a 230 second delay is required to keep the audio and video synced on blu ray discs since this happened. Very weird.
